Main > Main Forum
Where does the wire attach to a coin mech to
Alienreb:
Okay, so if the coin mech itself doesn't have a switch for me to attach some "trip wire" to, then what kind of mechanism do I need to supplement the mechanism with so I can wire up my IPAC to it?
aramis:
dude, it's just a switch. :)
that's it...nothing complex about it.
You put a coin in the slot...the mech's job is to decide if the coin is good...if it's not, it gets rejected. If it's good, the coin falls out of the chute and trips the "credit" switch as it falls by.
The Ipac doesn't care what you wire to it as a "credit switch", as long as it is a N.O. switch w/ ground on the COMmon. It could be a pushbutton if you want...
Thenasty:
--- Quote ---Okay, so if the coin mech itself doesn't have a switch for me to attach some "trip wire" to, then what kind of mechanism do I need to supplement the mechanism with so I can wire up my IPAC to it?
Sasquatch!:
I did a write-up on this with BIG PRETTY PICTURES:
http://www.arcadeparadise.org/arcade/ap2/coindoor.html
Zipper:
--- Quote ---would it be possible to use different types of coins for credits.
i've been planning on something like this.
2x 1 kr. = 1 credit
1x 2 kr. = 1 credit
1x 5 kr. = 3 credits
how would it work with MAME.
Kr. are the coins here in Denmark :)
Hi Zombie,
Here's a picture of my mech. I believe this is like something you want.
It is a Mars111 mechanism with a credit board attached. It takes 10p, 20p, 50p and
