Author Topic: configuring mamewah??  (Read 879 times)
method
  • Last login:October 12, 2007, 11:41:09 am
« on: May 09, 2006, 12:06:28 am »
Im havin problems tryin to get mamewah started, ive followed the instructions as best as i can but still can't to seem to get it to run. When i start MAMEWah and select in the options menu to generate list nothing happens.
My mame.ini file looks like this..
### mame.ini (mamewah v1.61) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  C:\Documents and Settings\Owner\Desktop\MAME\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
emulator_executable                       C:\Documents and Settings\Owner\Desktop\MAME.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\mame\snap
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
can anybody tell me if my directories look off or if im missing sumthin obvious. thanks.
liquid8
  • Last login:June 11, 2017, 04:02:02 am
  • I working on it.. it'll be a while.
Re: configuring mamewah??
« Reply #1 on: May 09, 2006, 12:16:43 am »
For your roms folder you have ~\Desktop\MAME\roms. For your executable you have ~\Desktop\MAME.exe.
Hopefully you do have a \MAME folder on your desktop (as you have it in your roms path), therefore your executable should be:
C:\Documents and Settings\Owner\Desktop\MAME\MAME.exe
although I wouldn't really recommend keeping your mame folder with roms on your Desktop, unless you are just testing - store it somewhere permanent, like C:\mame.
Also, if you did not get a list when trying to generate, there is probably still something wrong with your roms and/or roms path.
method
« Reply #2 on: May 09, 2006, 01:01:23 am »
thanks alot mate, that got it workin. Knew it was sumthin stupid and obvious as that.. :P
method
« Reply #3 on: May 09, 2006, 02:12:09 am »
i got another question, im trying to change the layout of mame, i whipped up a lay file just to test it but i cant seem to find the file where you link the layout file. Also what size would some of you reccomend using in mamewah?
« Reply #4 on: May 09, 2006, 04:49:53 am »
mamewah.ini - set 'layout layoutname'
Size what??
method
« Reply #5 on: May 09, 2006, 07:29:53 am »
rite thanks for that got it workin, and sorry dont kno why i said size i ment resolution
« Reply #6 on: May 09, 2006, 11:42:19 am »
Oh well it depends on what monitor you're using and your personal preference really.  I use a standard res. arcade monitor and like to use 368x240.
