Main > Main Forum
Keywiz help needed
emerica:
The white stuff you are referring to is probably white lithium grease and IMO not recommended for what you want to use it for. White lithium is good for metal pats that rub together and the stuff can be a little messy.
Silicone spray is clear. It will say silicone spray on the can.
kiddk1:
you are correct, the furniture polish fozzy was referring to, is that something like murphys oil soap?
emerica:
that might work although I do not have any experience with it
Fozzy The Bear:
--- Quote from: kiddk1 on May 12, 2006, 01:03:39 pm ---you are correct, the furniture polish fozzy was referring to, is that something like murphys oil soap?
I can't give you brands.... I'm on the other side of the Atlantic.... Just look for something that says silicone wax polish and olny use a very very very small amount.
The worst thing you can end up with is a sticky surface. You really want to avoid that. A very clean dry mech is the the best thing of all.
Best Regards,
Julian (fozzy The Bear)
kiddk1:
thanks
