Author Topic: Sanwa Joystick Wiring...  (Read 2501 times)
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« on: May 02, 2006, 03:09:32 pm »
I just received some Sanwa parts from Ponyboy.  The joystick has 5 pins for wires.  However, I don't know what each pin goes with.  What's ground, what's down ect...
I searched around for this, but found no answers.  I could take it apart and trace it, but I'd figure I'd ask here first.  Does anyone know what pin goes with what?
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
Re: Sanwa Joystick Wiring...
« Reply #1 on: May 02, 2006, 04:59:30 pm »
Just dug the Multi out....
2nd picture..... from  left to right
Gnd.....Up....Down.....Left.....Right
That's what it looks like on mine....
TalkingOctopus
    • My Arcade
« Reply #2 on: May 02, 2006, 08:07:04 pm »
Excellent.  Thanks!
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« Reply #3 on: May 05, 2006, 01:34:36 pm »
if you wouldnt mind helping me out too.  Also what is the yellow piece for?  I have the 5 prong wire just dont know which wire goes where on my keywiz
« Last Edit: May 05, 2006, 01:39:17 pm by kiddk1 »
Its easy to like someone,
If you dont know them very well.
StuckInJapan
  • Last login:June 17, 2006, 07:53:12 am
« Reply #4 on: May 05, 2006, 10:20:12 pm »
kiddk1, that yellow piece is a restrictor plate used exclusively on Seimitsu sticks - if someone sold this to you as a Sanwa, you've been lied to.
The plate "restricts" the actual movement of the shaft:
using the top circular hole will make it an 8-way, the middle groove will
only allow 2-way movement, and the diamond shape at the bottom will make it a 4-way by making diagonals impossible.
Sanwas and Seimitsus use the same pin-out and are interchangeable,
so Orclord's post should apply to you as well.
kiddk1
  • HAP KI DO
« Reply #5 on: May 06, 2006, 09:47:23 am »
I actually was given this and some other controls when I purchased a cab, I just assumed it was a sanwa b/c it looks the same.  I plan on using it as a 4 way b/c I have 2 happs 8 ways.  thanks
