Author Topic: two versions of MAME under MAMEWAH  (Read 2235 times)
Breaker
  • Last login:April 16, 2024, 11:52:31 pm
« on: April 30, 2006, 06:30:22 pm »
Hello all,
I did a few searches for this info. but didn't find anything...
I'm currently running MAME 0.79 and MAMEWAH 1.52 on my (almost finsihed) CAB and I'm happy with this combination as it does everthing I need....except....I'd like to run MAME 1.05 for a couple of games that have enhancements since 0.79 (but only for these games). How do I go about configuring MAMEWAH to run a different version of MAME for these games?
Thanks,
Breaker.
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
Re: two versions of MAME under MAMEWAH
« Reply #1 on: April 30, 2006, 08:57:26 pm »
Just add a new emulator, with the same ini file as mame. So say mame.ini is for mame, just create a mame2.ini and that will be the new emulator with the new .105 executable.
Breaker
« Reply #2 on: May 01, 2006, 09:02:15 pm »
Thank Hiub1,
I think I understabd your instructions...a coupel of quick follow-up questions:
a) when you say create a new emulator, do you mean create a nwe emulator in MAMEWAH?
b) if the answer to 'a' is yes then this may be a mute question but here goes; let's say I want to run the 105 version of Robotron which I curently have in my list of favourites in MAMEWAH. Can I use that same list but modify the ini Robotron uses to point to MAME 105 instead of 0.79?
Thanks again,
Breaker.
Hiub1
« Reply #3 on: May 01, 2006, 09:22:52 pm »
The answer to your question is yes. Sorry if I wasn't being clear, finals this week and my mind is all over the place.
The answer to the second question is no. That is one of Mamewah's limitations, that each list is only configured for a single emulator. I vaguely remember Minwah saying something about this being worked on, but I imagine it would take quite a bit of restructuring to do.
Hope this helps.
« Reply #4 on: May 02, 2006, 07:21:08 am »
This has been possible for a while...I can't remember the exact version.  You have to use game-specific ini files, and (if you decide to upgrade) I would highly recommend that you use the latest beta version.
Hiub1
« Reply #5 on: May 02, 2006, 11:13:48 am »
Ah! Awesome! I actually just did a full upgrade to 1.61, back from who knows what version I was running from a couple of years back. That is good news, I might have to find a way to implement this function into my layouts.
Thanks, Fred.
unclet
« Reply #6 on: May 02, 2006, 01:26:06 pm »
MameWahv1.62b9 is much better than then v1.62 IMHO....... I would use this newest version (or it it b10 now ?) if you are going to upgrade ......
Hiub1
« Reply #7 on: May 02, 2006, 05:21:00 pm »
You guys are not helping. I have finals this week, I unplugged my MAME computer from my cab, which is a PITA to plug back in so that I don't get distracted, and now you tell me that the new Mamewah is tons better than v. 1.61. I am going to flunk out :/
Breaker
« Reply #8 on: May 02, 2006, 11:48:40 pm »
This is great news -  thanks Hiub1 and Minwah!
I'm already using game specific INI files to set resolution an otehr attributes like triplebuffering; so the million dollar question is, what would a game specific INI file look like if I wanted to use a different version of MAME for a particular game? And, are we talking about a MAMEWAH a MAME INI files?
As I mentioned, I'm running MAMEWAH 1.51, so I'll give it a try on this version (keeping my fingers crossed).
Cheers,
Breaker.
« Reply #9 on: May 03, 2006, 05:18:32 am »
Well these are Mamewah game-specific inis...
Place an empty file named 'gamename.ini' in the \mamewah\config\emuname\game folder...run Mamewah and it will be automatically populated.  Then just edit it and adjust the emulator_commandline accordingly for the different emulator.
Mamewah v1.62b10 is the one to use...
Breaker
« Reply #10 on: May 04, 2006, 01:03:04 am »
Thanks Minwah,
I checked my MAMEWAH install and I don't have a '\mamewah\config\' directory - do I need to create this? Would it look something like this:
\mamewah\config\mame\robotron
Also, you mentioned that I should use v1.62b10 however, v1.61 is the latest version available on your site....
Cheers,
Breaker.
whatisk
  • Last login:March 27, 2017, 06:41:39 am
  • Nothing to see here
« Reply #11 on: May 04, 2006, 01:22:33 am »
Thanks Minwah,
Cheers,
Breaker.
1.62b10 is available here as it's currently in beta still.
Mamewah 1.62B10 thread
« Last Edit: May 04, 2006, 01:24:22 am by whatisk »
No trees were harmed in the creation of this post. Though several electrons were severely inconvenienced.
Breaker
« Reply #12 on: May 04, 2006, 11:17:55 pm »
Got it!
Thanks all.
Breaker
Breaker
« Reply #13 on: August 11, 2006, 10:19:15 pm »
Hi all,
OK, long time no post on this one!
I've finally had a chance to test this version of MAMEWAH to see if I could use two different versions of MAME within the same list - and it works great!
If you read my earlier posts, I was running MAMEWAH 1.52 with MAME .079 and wanted to configure MAMEWAH to use a newer version of MAME when running Robotron only (to take advantage of the timing fix available in later versions of MAME for this title). As Minwah indicated, this is possible using MAMEWAH v1.62b10. I have now successfully gotten MAMEWAH v1.62b10 to do what I wanted. Here is the contents of my 'robotron.ini' file:
### robotron.ini (mamewah v1.62) ###
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      e:\test\mame101\mamepp.exe [name]
post_emulator_app_commandlines
Thanks to Minwah and all for the help!
Breaker.
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #14 on: August 11, 2006, 10:58:43 pm »
Anyone know if beta 9 allows this as well, I'm 100 miles from my arcade to check. I know minwah made some small changes between the two, but I don't know if this was one of them.
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #15 on: August 18, 2006, 01:54:46 am »
Is there a list available that shows what is the "best" version of mame to run for each (or atleast most) games?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #16 on: August 18, 2006, 03:47:23 am »
Yes it does.
brophog
« Reply #17 on: August 18, 2006, 05:24:18 am »
No and even if there was, would you ever be able to use it to it's full potential? Probably not, considering the enormity of the situation.
However, there is a resource that let's you quickly find out problems and WIP notes on each rom. It lets you know the status of each driver and a list of changes for each rom.
http://www.mameworld.net/maws
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« Reply #18 on: August 18, 2006, 05:32:40 pm »
I have 2 versions of MAME, 1 version of Zinc and Daphne all in the same list. I just point mamewah at mame.bat which looks like this:
rem This batch file tries to add multiple emulator support for a single MAMEWAH list.
rem Currently I use it to do the following:
rem I use MAME .70 for some games that run too slow on modern MAME versions like .95
rem I also use a newer version of MAME to run the cruisn games which were fixed
rem     at some point.
rem And since Zinc uses the same roms as MAME I use Zinc to launch games like Tekken3.
rem     although MAME actually has better support for Strider2 and runs it just fine
rem         so I hand pick which ones to run.
rem I also added Daphne support
rem this is what my commandline from mamewah.log looked like
rem c:\progra~1\ekmame\ek-mame.exe MK2 -mouse -skip_validitychecks -skip_warnings -skip_startup_frames 999 {flags=9}
rem So I just mimic that here
rem Delete "/I" if you are not on an NT based system
rem /I is for Case insensitive matching.
@IF /I "%1" == "crusnusa" GOTO mame95
@IF /I "%1" == "crusnexo" GOTO mame95
@IF /I "%1" == "crusnwld" GOTO mame95
rem Daphne games
@IF /I "%1" == "dlair" GOTO daphne
@IF /I "%1" == "ace" GOTO daphne
@IF /I "%1" == "badlands" GOTO daphne
@IF /I "%1" == "mach3" GOTO daphne
rem Zinc games
@IF /I "%1" == "TEKKEN3" GOTO tekken3
@IF /I "%1" == "SFEX" GOTO sfex
rem Default case below
rem This should point to your main MAME version
cd c:\progra~1\ekmame\
c:\progra~1\ekmame\ek-mame.exe %1 -mouse -skip_validitychecks -skip_warnings -skip_startup_frames 999
GOTO END
rem exceptions below
rem This one should be your secondary MAME version
rem Note that you may not want to pass the same command flags to mame that I do.
:mame95
cd c:\progra~1\Ek-Mame99\
c:\progra~1\Ek-Mame99\ek-mame.exe %1 -mouse -skip_validitychecks -skip_warnings
GOTO END
:daphne
cd e:\daphne\daphne.exe
e:\daphne\daphne.exe %1 vldp -framefile "e:\daphne\mpeg2\%1.txt" -fullscreen
GOTO END
:tekken3
cd c:\progra~1\zinc\
c:\progra~1\zinc\zinc.exe 61 --use-config-file="C:\Program Files\zinc\zinc.cfg" --use-renderer-cfg-file="C:\Program Files\zinc\renderer.cfg"
GOTO END
:sfex
c:\progra~1\zinc\zinc.exe 12 --use-config-file="C:\Program Files\zinc\zinc.cfg" --use-renderer-cfg-file="C:\Program Files\zinc\renderer.cfg"
GOTO END
rem finish up
:END
exit
This will work on older versions of MAMEWAH.
Joseph Elwell.
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
« Reply #19 on: August 26, 2006, 09:44:05 am »
Joseph, that's  a simple, yet great, idea!
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
