Author Topic: CPO mounting help needed  (Read 648 times)
reko19
  • Last login:February 27, 2024, 12:43:51 pm
« on: April 27, 2006, 12:32:11 pm »
I am mounting CPO on top of the plexi. CPO is a self-adhesive vinyl.  I have one area about 3
daver
  • Last login:April 08, 2018, 08:08:14 pm
Re: CPO mounting help needed
« Reply #1 on: April 27, 2006, 12:34:54 pm »
why noy put the CPO under the plexi, so the pelxi would protect it, and hold it down?
reko19
« Reply #2 on: April 27, 2006, 12:38:11 pm »
I wanted to be able to get access to joysticks that are surface mounted under the plexi. Also, a lot nicer feel than the plexi.
bigtimes
  • Last login:November 02, 2016, 11:50:34 pm
  • Showcase-Style, baby
« Reply #3 on: April 27, 2006, 12:39:08 pm »
He's already placed it on the plexi, that's why.
You could try ironing it, I suppose. No steam, with a piece of newspaper over it, medium heat, then place your weight over it again. beyond that, maybe you could get another piece of plexi and put it down on top of your artwork.
If it were me, I'd simply start over.
reko19
« Reply #4 on: April 27, 2006, 12:43:08 pm »
I'll give it a try. Starting it over means paying for the new CPO, taking all controls out, re-doing the plexi and the T-Molding. :(
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« Reply #5 on: April 27, 2006, 02:04:15 pm »
I used some wall paper seam sealer on some artwork that was coming up off of laminate.  Might work for plexi, but can't be sure.  Worked well on the laminate.  Available at home improvement stores for a couple of bucks.
