Main > Woodworking
Which wood?
Wienerdog:
Another site comparing the woods (no weights though):
http://www.phillipsplywood.com/plywood_cores.htm
RandyT:
--- Quote from: Wienerdog on February 28, 2003, 07:57:55 pm ---Medium- and High-Density Overlay Plywood (MDO and HDO)
MDO and HDO consist of a core material, like laminated fir veneer, overlaid with a pressed fiber material. In short, this is a typical veneer core plywood (common plywood) with an MDF surface. This gives the best of both worlds; the weight is lower than a full MDF, but the surface is more stable than a veneer core plywood.
Check out this link for a better explanation of MDO. MDO isn't plywood with an MDF layer. MDF is not exterior grade or even remotely weatherproof.
http://www.rfpco.com/product_mdo.htm
RandyT
Wienerdog:
No problem, that is just what one site called it, here is a picture of it:
Matan:
thats regular plywood. thick tho
Xphile:
--- Quote from: Matan on February 28, 2003, 10:07:08 pm ---thats regular plywood. thick tho
that's probably only 3/4 thick...thin plys...you can get 3/4 " ply from 7 to 13+ layers..:-) more plys is better, but more expensive.
of course i'm blitzed, so take anything I say on a friday with a grain of salt.. (i'm guessing i'm still sober enough to recognize high quality ply in a pic tho':-)
Navigation
[0] Message Index
[*] Previous page
Go to full version
