| Main > Software Forum |
| Mamewah 1.62 issue |
| << < (2/2) |
| Minwah:
You only seem to have one theme (jcrouse), which explains why there is no 'Select Theme' option. Not sure about the platform tho... Try re-downloading and extracting (using WinZip) mamewah.exe - some other decompression tools have been known to mess up the exe and cause very similar problems. I might add something to the log in future to show the enumeration of platforms/list/themes etc. to show if things are somehow being 'missed'. Also, I need to ensure file attibutes don't play a part. |
| ppilot:
Thanks Minwah. Actually, theme shows up under all my other machines. When I key it, it says 'jcrouse' and 'default'. Any other thoughts? |
| Minwah:
--- Quote from: ppilot on April 24, 2006, 08:01:21 pm ---Thanks Minwah. Actually, theme shows up under all my other machines. When I key it, it says 'jcrouse' and 'default'. Any other thoughts? --- End quote --- I should have asked before...are you using the latest beta (v1.62b10) ?? In short...if you have checked all I've mentioned then I can't think of anything else...all I can suggest is you double check the file attributes etc - have a play and see if it makes any difference. I'll try to add some extra info to the log for the next beta which should make it easier to diagnose. |
| ppilot:
Yep, 1.62b10. If I'm understanding you properly, all of the files have the 'archive' attribute set (on all of the machines) so I don't think that's a problem (I'm assuming you were thinking the 'read-only' one was on?). I guess I'll just wait until the next beta comes out and try it again. Thanks for your help. |
| Minwah:
--- Quote from: ppilot on April 26, 2006, 07:19:23 am ---Yep, 1.62b10. If I'm understanding you properly, all of the files have the 'archive' attribute set (on all of the machines) so I don't think that's a problem (I'm assuming you were thinking the 'read-only' one was on?). --- End quote --- Yes, ensure 'archive' is set, and read-only and hidden are not set. Sorry can't be much more help until I add some things in...let me know how you get on with the next beta. |
| Navigation |
| Message Index |
| Previous page |
