Author Topic: [Got, thanks JDShaffer :-)] WTTF: some DB-9 connectors  (Read 1182 times)
o-o
  • Last login:January 13, 2023, 05:40:36 am
« on: April 17, 2006, 10:02:34 am »
Edit:
I'll trade for some DB-9 connectors (one male, one female)
my available trade list:
http://forum.arcadecontrols.com/index.php?topic=49230.0
user 'dabone' helped explain the diagram, its much simpler than I thought, and I already have a regular serial cable which has a broken end, so I just need some DB-9 connectors now
« Last Edit: April 28, 2006, 04:45:38 pm by o-o »
unclet
Re: WTTF: simple serial cable built
« Reply #1 on: April 17, 2006, 10:44:41 am »
Are you just requesting that a serial cable (male/female) wire be cut in the middle and the 9 internal colored wires be soldered together to match your diagram?
If so, then I guess you do not own a soldering tool ...... or perhaps you need the special "double-shielded" type serial cable?
« Last Edit: April 17, 2006, 10:48:27 am by unclet »
o-o
« Reply #2 on: April 17, 2006, 09:26:55 pm »
I wasnt completely sure of how to do it, or what the diagram meant..
Does it mean: just 4 wires are connected, 3 of which need diodes, and a few pins at each end are merged (?) [can those be merged for sure in the middle, or is there a possibility of the device needed them merged only at the ends?].
I thought it would be easier to trade for from someone who has made a custom serial cable before... and has spare parts, I dont have spare serial cables etc..
Im not sure if double shielding would be necessary or not (for a graphic tablet)
dabone
  • Last login:October 31, 2023, 12:03:37 pm
  • Time to work...
Re: WTTF: some DB-9 connectors
« Reply #3 on: April 18, 2006, 02:25:43 pm »
Dude, shipping on the connectors is  more than the cost.
http://www.radioshack.com/family/index.jsp?categoryId=2032285&cp=2032058.2032231&allCount=18&fbc=1&f=PAD%2FCable+Type%2F9-position&fbn=Cable+type%2F9-position
Run to radio shack and grab a couple.
Later,
dabone
unclet
« Reply #4 on: April 18, 2006, 03:22:08 pm »
I think the problem was not knowing how to intepret the diagram itself rather than not being able to find a serial cable.    He mentioned "diodes" might need to be required ..... I am not sure how to read the diagram if diodes are required.
I thought he wanted some wires connected from the male to female ends and that was it .....
o-o
« Reply #5 on: April 18, 2006, 11:49:49 pm »
I looked before and they seemed to be around $5 each
The ones you show in the link are just the tips/ends, casings are still needed,
ends up being about $7 new for the parts needed.. worth trying to trade for first if I can..
shipping should minimal
thanks
JDShaffer
  • Last login:September 30, 2014, 10:15:59 am
« Reply #6 on: April 19, 2006, 12:48:30 pm »
The cable doesn't use any diodes.  The arrows are just to show which way data will be traveling.  I have plenty of spare parts laying around to make the cable, except I can't do the metric screws on the other side.  If you will cover shipping cost.
« Last Edit: April 19, 2006, 04:15:23 pm by JDShaffer »
JDShaffer
« Reply #7 on: April 20, 2006, 05:55:59 pm »
I put your package in the mail today.  Shipping wasn't even $2, so don't worry about it. ;)
o-o
Re: [Got, thanks JDShaffer :-)] WTTF: some DB-9 connectors
« Reply #8 on: April 28, 2006, 04:46:56 pm »
thanks so much
