Author Topic: -skip_disclaimer "unknown option"  (Read 2511 times)
spongebue
  • Last login:April 20, 2006, 03:50:32 pm
« on: April 16, 2006, 02:17:56 pm »
I've done a ton of searching on this, and I'm having to resort to starting a thread around here.  Aw well, hope it works out...
I'm running the latest version of mame (though I had the same problem with an older version) and the -skip_disclaimer option when starting MAME does not work, it just gives a parse error.  I have tried to get the same thing done by using a mame.ini file, and I got something similar (it ignored it rather than aprupt the whole thing)
I do know a little bit of C, so if I have to dig into the source a little bit and recompile, that is not impossible with a little pointing in the right direction.
By the way, -skip_gameinfo works, and -skip_warnings does not. (same symptoms
Any help is appreciated, of course.
Thanks,
spongebue
Buddabing
Re: -skip_disclaimer "unknown option"
« Reply #1 on: April 16, 2006, 06:37:45 pm »
It's been removed.
Please read the wiki!
spongebue
« Reply #2 on: April 17, 2006, 10:32:30 am »
Awww, dernit!  Oh well, I was able to just copy Mame over from another computer I have, and that works well enough :)
Lilwolf
« Reply #3 on: April 17, 2006, 12:27:25 pm »
btw, it was removed because it only shows up once per game now.  It's not that bad...
Havok
  • Trade Count: (+17)
« Reply #4 on: April 17, 2006, 02:20:06 pm »
You can recompile mame to remove the disclaimer...
bleemus
  • Last login:September 01, 2016, 12:53:24 pm
  • Party Pengo in the house.
« Reply #5 on: June 08, 2006, 05:08:09 pm »
I just recompiled mame .106b with the skip_disclaimer and skip_warning re-enabled in the config file... if anyone wants it, PM me and I'll email it to you.
Reality is overrated.
