Main > Main Forum
Cocktail cab for outdoor use
arcade-mad:
Ok guys im gunna give it a go ill take pics when i start just in the planning stages at the moe.
Ive already got my joys buttons i pac pc and 21" monitor so should be starting soon i hope.
Im starting a bartop aswell so gunna be busy ;D
CheffoJeffo:
I would love to be proven wrong here and am looking forward to seeing what you come up with!
Cheers.
leapinlew:
--- Quote from: arcade-mad on April 15, 2006, 06:31:57 am ---i have a cab in the dining room but its hassle in there as all lads seem to stay in there while the ladies are in the garden.
I don't see the problem here. Keep the cab in the dining room and then you go in the garden. Let the dudes play video games and you can work on the ladies.
ssc arcade:
More power to you it you can get it going.
I don't only see problems with the monitor and CPU but the microswitches also and Joysticks, moving objsects will be hard to seal around. You can cover them up to keep direct rain off, but a very wet day 100% moisture in the air will get everything wet inside if there is any outside ventilation.
I know this is a compromise, but I would make a sort of bar top with 4 handles on top to help 4 guys take it outside. If you want make a base to stay outside that it can sit on to get to the right height with a plug right there, keep the bartop inside except for parties.
Take some weight out to help, but most of a cabs weight is 3/4" MDF, bartop takes more than half the weight out. when the guys comeover have the first couple help you carry it out. Get creative and make it somewhat lighter, with a good way to lock it down.
A compromise, but I would hate to see a project end up a home for mice and wasps.
ninnghizidha:
Did you know that you can put the whole PC and the television set into a aquarium filled with oil? They will still work and you don't need to worry about humitity any more. ;D
Of course you still will have to care about the buttons and the table, but there would one big trouble less.
Ninn.
