Author Topic: Electrical Question - is 12v from a cigarette lighter the same as 12v from a pc?  (Read 918 times)
I am building a jukebox that I plan on posting in the projects section soon. I have some red neon subwoofer lights that mount to those subwoofer boxes those crazy kids have nowadays. It comes with a 12v cigarette lighter adapter and I am assuming I can hack the wire and connect it to the 12v on my power supply of my computer.
What I know is they are both 12v and they are both DC. But, I don't know much about electric and not sure if there is a amp issue that could cause the lights to burn out quickly.
So, my question is: do I need to do anything special to get these neon tubes to work with my 12v PC power supply if they were intended for a 12v cigarette lighter?
Thanks in advance!
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
You should be fine running them off a PC 12V.  I used to run 12V 80mm computer fans in my old truck to keep the amps cool.
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
  • Last login:May 23, 2021, 12:53:30 pm
I have seen a cabinent once that had a car cigarette lighter on his CP... I was considering this but decideded against it what I quit smoking........
1 other questions:
How many of these 12v devices can I run off a single 12v connection from the power supply? Could I double them up? to get 2 devices to run off a single 12v wire?
ChriX
  • Last login:March 23, 2013, 05:02:04 am
You will be fine connecting more than one device to a 12V line on your PSU, especially with such low current items. The lines are only connected together when they get back inside the PSU anyway. You are right to think about the current flow in the lines, if it were too much the wires would most likely melt or the PSU would cut out, but with something like this the current is low anyway so you don't really need to consider it.
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
I'm not being too serious, but there's always: http://www.thinkgeek.com/pcmods/cables/6b35/
danny_galaga
  • Last login:Yesterday at 09:08:57 pm
    • dans cocktail lounge
there's nothing mysterious about all this. know how many watts your 12v supply can, well supply! and how many watts your devices draw. if the info you ahve is in amps well volts x amps = watts.
