May 08, 2024, 03:17:11 pm
Yes, the quick-disconnects/terminals. Are the .110 terminals needed for the Ultimarc controls? thanks
.156 connecters are incompatible with the controls, you don't need to use use .110 connectors... so, you can use standard .187 connectors. Is that correct?
