Author Topic: what is the average weight of a 4 player cab w/ a 25" monitor  (Read 923 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
Hi. I know this is an odd question but I'm terrible at guessing weight. I'm considering getting a four player t.m.n. turtles game. It would have to go up a narrow flight of stairs. I am wondering about how much it would weigh and how many guys it would take to move it.
Any info would be greatly appreciated. thanks
Havok
  • Trade Count: (+17)
Re: what is the average weight of a 4 player cab w/ a 25" monitor
« Reply #1 on: April 07, 2006, 08:13:18 am »
I would say about 300 - 400 pounds. Get a hand truck if you can. With two relatively strong guys you should be able to manage. Or, use four weak, skinny, girlie-men...
Ken Layton
  • Guru
  • Technician
« Reply #2 on: April 07, 2006, 11:23:06 am »
At least 350 pounds. Get a handtruck with stairclimbing belts above the wheels to make things easier. You'll need a minimum of two guys for sure but try to get three.
One thing that helps is to take that damn control panel box assembly off the cabinet so it lightens up the cabinet and makes it easier to turn corners.
Be sure to buy your helps several rounds of beer afterwords. :cheers:
chrisdfw
  • Last login:February 21, 2019, 08:50:58 am
« Reply #3 on: April 07, 2006, 03:42:07 pm »
African or European?
ssc arcade
  • Last login:October 07, 2008, 02:10:58 pm
  • There are no stupid questions, only stupid people.
« Reply #4 on: April 07, 2006, 03:47:34 pm »
African or European.........  I am not sure....   Ahhhhhhhhhhhhh.
Nice one.
I am surprised no one pointed out the obvious, I am sure you already checked, weight is one issue, but when you said four player cab and narrow stairs, I am a little concerned.
Make sure it will even fit before you wedge it up in there.
SithMaster
« Reply #5 on: April 07, 2006, 07:49:53 pm »
remove anything you can from it.  the monitor and cp defs and have two people on the bottom with someone pulling the cab with the handtruck.
Q*Bert_OP
  • Oh yes, we did!
« Reply #6 on: April 07, 2006, 09:31:02 pm »
Just a word of caution: It is  :censored: hard to put the monitor back in a Konami cabine if it is mounted on a shelf...
rlemmon
« Reply #7 on: April 07, 2006, 10:47:06 pm »
Thanks guys  :D
