Main > Main Forum
What 4-way does everyone use?
jdjuggler:
Hey Brax,
I was wondering if we could see any pictures of your mounting of the 4-way stick. I'd like to be able to mount mine as high as possible.
Thanks.
AndyWarne:
Note you can easily increase the spring pressure on the J-Stik if you wish, just unscrew the 4 screws holding the front-plate on, pull out the shaft, take off the circlip and stretch the spring. Re-assemble.
Andy
lightspeed:
I've got Happ's repro Ms. Pac Man stick, which uses microswitches.
I'm happy with it, but its hard to beat the old leaf-switch style sticks.
jdjuggler:
I'm interested in mounting the Ms. Pacman/Galaga 4-way on my CP, but I'm concerned about it being too low. Will a custom mounting plate bring it up higher?
Does anyone have pics of how this would be mounted without the stock mounting plate?
Thanks.
JD
