Author Topic: WICO Command Control (Thrift Store)  (Read 2066 times)
babydickonboard
  • Last login:May 22, 2008, 08:28:56 pm
  • {/....KILL YOUR TELIVISION....\}
« on: March 31, 2006, 10:03:56 pm »
SO on one of my stops today by the local saint vincent depauls, i came across this in the technology section.....
I'm pretty excited cause i ended up getting it for free from someone who works there.  ITs a leaf switch style "WICO Command Control" for the Atari and some other systems.  It came w/ the orginal box, instruction booklet, and even the recipt for when it was purchased!  I opened up and it can easily be adapted to be used for a cab. I also read that the top fire handle can be used w/ an authentic wico base.
I'm kinda unsure about what I will do w/ it though.  Although it would be a great addition to my cab in progress if i could find a way to properly mount it, i wouldn't want to mutilate something that may have nostigic value to somebody.  Maybe if its worth sometbing to somebody becasue of the topfire button, a trade might be able to be made?
 I don't know, whats your guy's input on it?
babydickonboard
Re: WICO Command Control (Thrift Store)
« Reply #1 on: March 31, 2006, 10:06:12 pm »
umm...this might want to be moved to a different forum because its not technical a "review".
 :lame:
found a little review here : http://www.atarimagazines.com/v1n5/joysticksurvey.html
http://www.atariguide.com/10/1002.htm
of course its good by Atari controller standards.....
« Last Edit: March 31, 2006, 10:36:16 pm by babydickonboard »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: April 01, 2006, 12:36:54 pm »
Ebay link.
I prefer the ball top model for arcade cabinet use, but that's just because I like the "authenticity" of a ball top. A bat top probably would be easier ot handle.
The problem with adapting it for an arcade base will be grinding/shaving away some of the metal shaft.  Next problem is that if you want to keep the original button mechanism, you'll have to find a way to mount the leafswitch.
Read all about it here: http://forum.arcadecontrols.com/index.php?topic=20914.0
NO MORE!!
MinerAl
  • Last login:March 21, 2023, 07:11:28 am
  • duck
Level42
« Reply #4 on: April 01, 2006, 06:15:26 pm »
Yeah I picked up two of the ball handle top-fires for a mere
« Last Edit: April 01, 2006, 06:17:18 pm by Level42 »
babydickonboard
« Reply #5 on: April 01, 2006, 06:38:32 pm »
well then, i think i'm going to wire up an atari connector and try the stick out w/ the leafs that it has now. if i like it, i'll probaly end up trying to find a way to mount to my control panel. plus the red and white will match my current cp color scheme.  i'll post the results when it happens.
