Author Topic: Cheap super bright 12v leds  (Read 3777 times)
eightbit
  • My cab is never done...
« on: February 25, 2003, 09:48:51 am »
A source for cheap super bright 12v LED's was mentioned in chat last night-
http://superbrightleds.com/1157.htm
It looks like a very simple cheap way to light up a trackball or some buttons. No figuring out or wiring diodes simply hook them to 12v and go.
TazMan
  • Last login:May 08, 2020, 12:24:38 pm
  • It's no easy being green.
    • What is the MAMEtrix?
Re:Cheap super bright 12v leds
« Reply #1 on: February 25, 2003, 10:14:02 am »
Another nice thing about these is that they are T 3 1/4 wedge base - which means they fit into the sockets provided on Happ coin doors and illuminated push buttons and are much cheaper than the $14.25 white wedge base Leds Happ sells
« Last Edit: February 25, 2003, 04:48:45 pm by TazMan »
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
« Reply #2 on: January 07, 2004, 12:29:01 pm »
Thx for the info!!  I wasn't prepared to pay happs prices for LEDs... :P
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
SS427
  • Last login:October 07, 2017, 12:04:24 am
  • Slow Poke, He pack a gun!
« Reply #3 on: January 07, 2004, 01:59:52 pm »
I have recently added two of the wedge type leds for my trackball and I am also using them to light the coin doors.  They seem to work great.  The 1157 type leds put out a lot of light.  I am planning on using it instead of the wedge type for the trackball.  The wedge type lights the trackball, but I have them mounted like the typical trackball lights and the main part of the light from the leds is not in the correct direction (still works good though).  When I was testing the 1157 types, they were held under the trackball and lit up the ball really well (it also put a lighted spot on the ceiling), but a mounting bracket has to be put together to attach it to the trackball.
I ordered some extras (wedge type and 1157/1156 type) that will soon be sent to Kevin Steele for a proper review.
IMO, they seem like a good alternative for functionality and price.
ss
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #4 on: January 07, 2004, 03:14:27 pm »
I've used this company many times for my personal and school projects. Very very fast shipping. Plus, you get a free ugly sticker!
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
rdagger
« Reply #5 on: January 07, 2004, 03:15:29 pm »
I was trying to illuminate a clear 3" trackball with a super bright LED last night and was not having much luck.  The super bright LED's emits a very focused beam which the spherical trackball seems to focus even more.  The end result is that I get a weakly illuminated trackball and a very bright colored 10" circle on my ceiling.
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #6 on: January 07, 2004, 03:29:51 pm »
This might help or might not. Try putting a piece of wax paper over the LED this might help diffuse the light. Or any plactic that lets light through but is not clear.
Curls in the squat rack !?!?!
SirPeale
  • Green Mountain Man
« Reply #7 on: January 07, 2004, 03:32:25 pm »
The problem is you're using a clear trackball.  LEDs are very focused.  Pretty much a beam of light is just passing thru and shining on the ceiling.
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« Reply #8 on: January 07, 2004, 03:32:56 pm »
Are 12 or 19 LED clusters a bit of overkill for a TB or coin door?
%$#@!&* machine took my quarter!
TazMan
« Reply #9 on: January 07, 2004, 03:46:29 pm »
I used the 1 bulb LEDs for my illuminated pbs, and 4 bulb leds for the coin door and trackball and they worked like a charm.  By using green leds on the coin door, the buttons appear green, even though they are yellow plastic (default Happ color)
« Last Edit: January 07, 2004, 03:47:24 pm by TazMan »
SS427
« Reply #10 on: January 07, 2004, 05:06:19 pm »
rdagger,
To clarify....The leds (wedge type) that I am currently using for the trackball have a "plastic lens cover" which is not quite clear that helps diffuse the light.  I cannot tell that I am getting much of a focused light pattern at all (don't know if you were using leds from the company in question or regular super bright leds)....The 1157 I mentioned has a cluster like the ones Oldskool mentioned and if they are the same, I did get a light spot when testing it (they have a clear lens).
I only used one of the wedge type leds for my coin doors (with offwhite lens) and have been happy with them.
ss
rdagger
« Reply #11 on: January 07, 2004, 09:29:03 pm »
Actually the clear trackball is narrowing the beam.  When I plug the LED into a bread board it illuminates my ceiling with a 4 foot circle.  When I hold the trackball over the LED, the circle on the ceiling reduces in size to about 10 inches.  The trackball is acting like a magnifying glass.  I was thinking I might be able to use some type of lens to dampen the effect.
It also is not very good for the eyes when you look straight down into the ball.
Clonedsheep
  • Last login:August 03, 2021, 07:11:08 pm
Re: Cheap super bright 12v leds
« Reply #12 on: December 15, 2005, 01:58:56 pm »
I need to check this info for later so *bump
The king of 1/2 done projects
