Author Topic: Can I do this with MAMEwah?  (Read 1500 times)
bsweet0us
  • Last login:December 18, 2020, 09:59:46 am
« on: March 26, 2006, 07:28:04 pm »
Okay....did some searching (here and Google) to no avail, but I figure if anyone can do this, they hang out here.
I currently have MAMEwah launching from a shell as to avoid as much computer look as I can....even got it exiting to a desktop with the escape key.
I also have an intro movie in MAMEwah which I would like the ability to stop and enter directly into the MAMEwah interface with the press of a button (or a hotkey.)
I think this has to be done through the ctrlr file, but not really sure if there's a command to do that.  Any help would be greatly appreciated as this would pretty much finish off the software portion of my cab.
Re: Can I do this with MAMEwah?
« Reply #1 on: March 27, 2006, 03:36:13 am »
Sorry but there is currently no way to skip the movie.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:December 23, 2023, 07:05:04 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #2 on: March 29, 2006, 04:32:17 pm »
Minwah, not sure if you formally track feature requests or anything, but I'd like to second the request for a 'movie interupt function' as a future feature if you ever do a new release.  The movie is cool for most times when you have guests, but when you are booting up the Mamewah for the thirteenth time in a day it gets old.
« Reply #3 on: March 30, 2006, 10:37:52 am »
I know when I added the intro movie feature I knew this 'skip' function would be handy.  However I also know that I didn't add it, basically as it was more tricky than it seems.
However I'll add it to my todo list...just note that for the moment I'm not really considering this a priority  :-\
jcrouse
    • CPViewer
« Reply #4 on: March 30, 2006, 02:59:06 pm »
I have to ask, only because you mentioned it  :hissy:, what exactly are the priorities?
John
« Last Edit: March 30, 2006, 03:01:44 pm by jcrouse »
cobey
  • Last login:April 20, 2006, 12:08:06 pm
« Reply #5 on: April 01, 2006, 12:00:52 am »
GIRLS, BOOZ, and STRIP ARCADE?
  • Last login:May 03, 2024, 11:58:33 pm
« Reply #6 on: April 04, 2006, 03:15:16 pm »
Better trust minwah on this one, it's much harder to do then you would think.  I had that option in dk early on and it turned out to be "breaking" a lot of other things, causing some systems to crash.  I ended up having to take out the option.
The solution I found was to check to see if a key is pressed before running the movie routine.  So bascially you can't skip a movie once it's started, but if you are holding down a key during bootup it'll skip it. You might wanna try fixing it that way, saves a lot of headaches.
« Reply #7 on: April 11, 2006, 06:04:02 am »
Basically fixing some bugs (I seem to have 8 or 9 atm) and adding one or two new features (you probably know which ones ;) )
However real life is taking most of my time at the mo and since my cab is not at my home motivation is dwindling a little bit.  Hopefully when summer arrives I'll take my cab apart and transport it to my new abode  8)
