Author Topic: promblems with atomicfe and using it as a shell????  (Read 852 times)
squire
  • Last login:May 06, 2014, 12:31:17 pm
« on: March 24, 2006, 11:37:41 pm »
im still having troubles i can not for the life of me get it to work....
here what i do
well first this is where my atomic is found at
c:\atomicfe
then i open up new text document in that document i write the following  exactly
c:
cd \
cd atomicfe
atomic.exe
save it so it says atomic.BAT
then i keep it in the same folder as atomicfe
and then put it in the windows folder
then open regedit
HKEY_CURRENT_USER\ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \Winlogon
Add or Edit the Key : Shell
And put Shell = Atomic.BAT
like this
save it exit restart and no luck, when it boots it does nothing just goes back into windows like nothing happend,am i doing som thing wrong?
« Last Edit: March 25, 2006, 12:06:28 am by squire »
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
Re: promblems with atomicfe and using it as a shell????
« Reply #1 on: March 25, 2006, 12:17:34 am »
...Think you have to spell out the full path if you are not using explorer
eg   c:\windows\Atomic.BAT
also I think it is fussy about capital letters so make sure the file name matches exactly
squire
« Reply #2 on: March 25, 2006, 12:06:58 pm »
yeah i tried that also i dont understand i guess. i just cant get it to work,i have to be doing somthing wrong...
squire
« Reply #3 on: March 25, 2006, 01:02:31 pm »
ok well i got it to work but i still get a boot screen before the app launches is there a way to get rid of this
loadman
    • MaLa
« Reply #4 on: March 25, 2006, 04:50:50 pm »
..Do a search
There is many threads on hiding XP
 :P
squire
« Reply #5 on: March 25, 2006, 09:59:46 pm »
thanks
but i have windows hiding pertty well!
but there a little screen that appears when the .bat file runs, then the app launches!
thanks that what i was talking about sorry!
