Author Topic: arcadeos  (Read 2543 times)
vipezz
  • Last login:May 03, 2009, 12:24:30 pm
arcadeos
« on: March 24, 2006, 02:35:52 pm »
ok i'm new here, so hi to all off you  ;D
now to the real point, i have a problem :(  .
i set up an arcade machine to work with my pc for mame and stuff. i formatted the pc, i installed mame and i installed arcadeos. i left the settings for mame unchanged. for arcadeos i only changed the options
vipezz
Re: arcadeos
« Reply #1 on: March 25, 2006, 12:23:43 am »
nobody? :cry:
lokki
  • Last login:June 29, 2017, 12:57:48 pm
Re: arcadeos
« Reply #2 on: March 25, 2006, 12:44:43 am »
Kind of hard to follow what you are doing.
ArcadeOS With Arcade Monitor works OK
MAME with Arcade Monitor does not work
What version of MAME are you using? what games are you trying? What resolution are they?
What video card are you using?
From your question it looks like ArcadeOS is working as expected, but you need to configure MAME to work with Arcade Monitor
vipezz
Re: arcadeos
« Reply #3 on: March 25, 2006, 04:40:42 pm »
that probably is the problem, could you please tell me how to do this cause i havent modified mame in any way yet, you know how to configure it for the arcade monitor?
lokki
Re: arcadeos
« Reply #4 on: March 25, 2006, 06:06:48 pm »
you have not answered any of the questions. What Video Card are you using?
What version of MAME are you using.
http://www.mameworld.net/easyemu/mameguide/mamedossetup.htm
http://www.mameworld.net/dosmame/advanced.php
vipezz
Re: arcadeos
« Reply #5 on: March 25, 2006, 06:47:09 pm »
oops sorry about that m8, i use a nvidia geforce4 ti4200 card,
i used mame but after your second post i tried the dosmame, wich runs fine, but now when i load a game the screen is really small :(.     btw, i dont know if this works but would i be able to play n64 games trough the arcadeos on my arcade monitor?
edit: the screen is perfect now, i can play games, buti have no sound, i tried all seven soundcard modes available in arcadeos but none works.
« Last Edit: March 26, 2006, 04:46:08 am by vipezz »
SirPeale
  • Green Mountain Man
Re: arcadeos
« Reply #6 on: March 26, 2006, 07:37:37 am »
i used mame but after your second post i tried the dosmame, wich runs fine, but now when i load a game the screen is really small :(....
Are you using Windows, or DOS?  ArcadeOS and dmame should be run under DOS *only*.
As for your sound issue, you didn't mention your sound hardware.  The included drivers only work on those particular chipsets.
vipezz
Re: arcadeos
« Reply #7 on: March 26, 2006, 08:40:13 am »
i use windows xp, i aint that much of a hero in DOS. :(
as for the sound problem, i use avance97. so i guess, i'll have to buy a new soundcard to get the music going?
SirPeale
Re: arcadeos
« Reply #8 on: March 26, 2006, 02:18:27 pm »
ArcadeOS is a DOS ONLY application.  You will have other issues at hand then the ones you have already encountered.
I've heard of AC'97 sound drivers for DOS, but never explored them.
Havok
  • Trade Count: (+17)
Re: arcadeos
« Reply #9 on: March 28, 2006, 10:26:52 am »
XP can only drop down to 800x600, most likely that is your problem...
Slope
  • Last login:May 02, 2015, 03:43:21 am
Re: arcadeos
« Reply #10 on: March 28, 2006, 11:17:30 am »
I'm running Windows XP SP2 at 640x480 @ 60Hz....so it is possible.
Havok
Re: arcadeos
« Reply #11 on: March 28, 2006, 11:22:50 am »
True enough, but you had to apply a hack to get it down there...
SirPeale
Re: arcadeos
« Reply #12 on: March 28, 2006, 09:15:09 pm »
You can do it right from the control panel, no hacks needed.  Granted, it's a PITA, but possible.
