Author Topic: DESPRATELY NEED HELP - Scripting, PLEASE can someone assist!  (Read 846 times)
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
« on: March 24, 2006, 04:54:12 am »
Im trying to get virtua fighter 2 PC version to run on my cab. Now the game works fine but unless I change the frame rate options to full and not auto, it will run slow. To get to the options you need to tap F6. Now you might be thinking, simply change it to full and exit tyhe game and it will save the settings automatially - WRONG! The game does not save ANY graphics options, so I would have to manually press F6 each time I load the game - not the best of solutions for a cab!! There is also no ini file for me to config these options before launching a  game.
It would seem my only solution would be to write a script or macro that sutomatically  launches the game, goes into options, changes frame to full and exits f6 options back onto the game title screen.
I have NO idea how to do this.
Can anyone help, I would LOVE to have virtua fighter 2 on my cab.
If you need the game, please check the usual dubious sites or PM me
you CAN try the demo, for that goto:
http://www.download.com/Virtua-Fighter-2-demo/3000-7563_4-873473.html
or
http://downloads-zdnet.com.com/Virtua-Fighter-2-demo/3000-7563_2-873473.html
and goto: http://www.troyandjessica.com/downloads/vf2.zip
for the direct 3D patch - which I will be using.
« Last Edit: March 24, 2006, 07:16:24 am by darthbane2k »
jcrouse
    • CPViewer
Re: DESPRATELY NEED HELP - Scripting, PLEASE can someone assist!
« Reply #1 on: March 24, 2006, 05:50:21 am »
If you need the game, please check torrentsites such as mininova or PM me
I would modify your post. This will definately raise some eye brows.
John
darthbane2k
« Reply #2 on: March 24, 2006, 07:16:43 am »
BUMP
please can someone help
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: March 24, 2006, 07:37:44 am »
Sounds like you should make a batch file.  I'm changing my nick to captain obvious.
darthbane2k
« Reply #4 on: March 24, 2006, 07:58:03 am »
a batch file to do what? to press F6 , navigate through menus and change graphics settings for me?  :-\
I didnt know  a batch could do this. Please tell me how?
I think what I need is a script or a macro, and thats something I need help on
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #5 on: March 24, 2006, 08:02:47 am »
I believe you are correct.  I have taken the role of unofficial thread bumper.  I appologize for any inconvenience.
darthbane2k
« Reply #6 on: March 24, 2006, 09:38:37 am »
bump again
Havok
  • Trade Count: (+17)
« Reply #7 on: March 24, 2006, 10:03:44 am »
I do a lot of scripting at work. One program that you should check out is AutoIT - it is freeware, and can be downloaded from here:
http://www.autoitscript.com/cgi-bin/countdown.pl?AutoIt/AutoIt.exe
Version 2 is easier for someone new to scripting to understand. This may not work for you, if these menus are not "Windows compliant." So, at least I will give you a possible point to do what you are looking for.
Good luck!
