Author Topic: A couple questions regarding bolt patterns on many joysticks  (Read 1807 times)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« on: March 23, 2006, 05:34:11 pm »
I have been researching many different brand joysticks for a project and the results have really surprised me. Is it true that Happ, Betson, Wico and Sanwa joysticks all use the same 3" * 2.6" mounting pattern? Of course, I know some of the specialty Happ ones, like the trigger stick and ball-tops, use different bolt patterns. I'm just wondering which ones by the other companies I listed have strange bolt patterns.
Also, what is a good standard size shaft hole? I understand that many of the standard ones only need 1 1/8", but that some of the  complex ones, like the P360, need 1 1/2". Can someone clarify?
Thanks for the help.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: A couple questions regarding bolt patterns on many joysticks
« Reply #1 on: March 24, 2006, 12:10:36 am »
You are correct about the mounting holes, and you can add X-Arcade to the list.  I dunno about the center hole diameter.
Tahnok
    • Table Arcades
« Reply #2 on: March 24, 2006, 04:17:23 am »
OK, thanks. I forgot about checking X-Arcade. That's a great help.
Any information regarding the hole diameter is still appreciated though.
Tahnok
    • Table Arcades
« Reply #3 on: March 27, 2006, 03:20:29 am »
Can anyone lend an opinion about the shaft hole diameter?
RichyRich
  • Last login:November 17, 2006, 12:22:40 am
  • If it ain't broke don't try and fix it
« Reply #4 on: March 27, 2006, 07:26:46 am »
The shaft hole diameter for the 360 doesn't have to be so big.Mine is only 12mm(under 1")and doesn't touch,thats on a 1/2" wood panel though.Hope this helps.
Havok
  • Trade Count: (+17)
« Reply #5 on: March 27, 2006, 09:27:49 am »
I used the same 1 1/8" bit for my 360 center hole as my buttons. It looks like you could use much less...
Tahnok
    • Table Arcades
« Reply #6 on: March 27, 2006, 02:59:56 pm »
Thank you very much. That's what I needed to know.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: March 27, 2006, 03:39:10 pm »
The total thickness makes a big difference.  3/4" wood plus 1/8" lexan top needs a bigger hole, while a 3/4" wood routed to 5/8 with not overlay can do the "normal" 1 1/8" hole, IIRC.
Robin
Knowledge is Power
RichyRich
« Reply #8 on: March 28, 2006, 07:54:43 am »
yeah thats right,that's why I included the thickness of the panel.Obviously the thicker the panel,the larger the hole has to be unless routing.Maybe I should of stated that.Thanks u_rebelscum.
