Author Topic: can i change the volue control in jamma arcade machine  (Read 4978 times)
grayxx
  • Last login:July 27, 2006, 07:25:32 am
« on: March 23, 2006, 05:02:43 pm »
i have a jamma arcade achine running puzzle bobble, and the sound is very loud how do i change the volume??
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
Re: can i change the volue control in jamma arcade machine
« Reply #1 on: March 23, 2006, 08:41:31 pm »
I'm not 100% sure for that machine, but for most, you Will find a potentiometer on the near the main circuit board, it will look something like the one below.  rotating the post counter-clockwise should decrease the volume.
Good Luck!...if you don't have one of those, I might suggest searching this forum and google.
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: March 23, 2006, 09:07:59 pm »
In Puzzle Bobble, I think the volume is set in the Sound Test menu (hit the Test button and select Sound Test from the menu).
I'm not 100% on this and don't have a manual handy, but it is a reasonable place to start.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: March 23, 2006, 10:41:18 pm »
That's Neo Geo isnt it?
NO MORE!!
CheffoJeffo
« Reply #4 on: March 23, 2006, 10:53:04 pm »
I was assuming original TAITO hardware (although I just checked KLOV and it says MVS only ... am I losing my mind ?? Wasn't this released on a TAITO board ?).
grayxx: If it is a NG cabinet, go to hardmvs.com, find the manual for your board and locate the volume control.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
grayxx
« Reply #5 on: March 24, 2006, 07:13:19 am »
ok im a bit mixed up here i have a jamma cabinet and the board is a neo geo mvs with the cartridge? also were is the test switch??
« Last Edit: March 24, 2006, 07:17:12 am by grayxx »
CheffoJeffo
« Reply #6 on: March 24, 2006, 07:24:11 am »
ok im a bit mixed up here i have a jama cabinet and the board is a neo geo mvs with the cartridge? also were is the test switch??
You think YOU'RE mixed up ? It is your machine, how can we tell you what you have ?  I am wondering how you know this is a JAMMA cabinet, but aren't sure what is inside. The MVS 1 slot boards were all JAMMA, so there isn't a big disconnect there (could be a bonus if it were true).
Open up the cabinet and take some pictures of what is inside (e.g. the game board) so we can advise you better. Because you did not mention NeoGeo, I initially guessed that you had dedicated TAITO hardware and last night found a Puzzle Bobble 2 manual that apparently matches my intial recommendation (so KLOV may well be wrong).
Much of the time, the test switch is located just inside the coin door.
Crack 'er open and post some pics .. at this point I am rather curious to see what is in there.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
