Main > Main Forum
Sheared-off screw head
danny_galaga:
so have you resolved this problem yet? and how so?
Lilwolf:
I've had that happen by breaking drill bits flush more then breaking screw heads off. (then I stopped trying to predrill with such a thin drill bit :)
--- Quote from: Buddabing on March 20, 2006, 07:37:32 pm ---@mccoy178:
The screw is a plain old wood screw, about 1/8" in diameter by 1/2" long.
The screw broke off below the surface of the wood.
I have learned my lesson about predrilling. :'(
@tahnok100:
There's a screw in the way. :) I dunno if there's a good way to drill that exactly through a screw.
Buddabing:
--- Quote from: danny_galaga on April 05, 2006, 04:40:24 am ---
I cleared off all metal parts near the screw. Then I used a magnetic stud finder to find exactly where the screw was. Next, I drilled a small hole to find the screw. I then enlarged and deepened the hole until I could get some needle-nose vise grips around the screw. Then the screw came out. I repaired the hole with wood putty.
nostrebor:
--- Quote from: Buddabing on April 05, 2006, 08:23:09 am ---
You might want to add that you did this from the back face of the PF.
Buddabing:
That's right, here's a picture of my vise grips clamping the screw shaft.
The hole I made is actually larger than it would have been had I drilled out the screw from the top, but I did not have to touch the top of the playfield at all. So I think this method worked out well.
