May 08, 2024, 02:28:51 pm
Just curious if anyone had bought either? Bought the mameroom cab with the slikstik CP, just the mameroom cab, or the slikstik cab and cp?or any general opinions on either would work too...thanks
how easy or difficult was it for anyone to get a WG D9200 into the UAII? and how does it hold up?ALso does anyone know if the UAII use MDF, particle board , or something else?Is this place comparable http://www.arcadeshopper.com/mame/mamekits.htm?
How are the joysticks connected to the panel on the slikstik?I am guessing there is some kind of screw under near that goes into the panel?Does it look like it is easy enough to remove and replace a joystick without damaging the CP?
