Main > Main Forum
used all 56 inputs on ipac4, now how do i get 3 admn buttons to work?
ahofle:
--- Quote from: pointdablame on March 15, 2006, 12:33:14 am ---
--- Quote from: ahofle on March 14, 2006, 07:23:38 pm ---Not that I think it's a great solution, but it would technically work. Your characters in Gauntlet do not appear just by inserting coins. You also have to subsequently press the start/magic button after inserting the credits. Not sure about Xmen, but I suspect it would behave similarly.
Nope, Xmen, TMNT, and a bunch of other 4p games pop a character on screen once you drop a coin in. The coin slots correspond to certain characters, and coining up puts the player on the screen.
You could choose characters in those games by using the 2p versions, but that's silly if you have a 4p control panel.
Well I tried TMNT and it does not 'pop up' a character either when you insert a coin. It just says 'press start' next to the player 2-4, similar to gauntlet. I don't have Xmen to try though.
--- Quote ---The point: DO NOT MAKE ONE CREDIT BUTTON INSERTS COINS FOR ALL PLAYERS.
Note I didn't think it was a good idea either, just nitpicking a minor incorrect statement. :)
Using the I-PAC shift functionality is obviously the way to go.
pointdablame:
--- Quote from: ahofle on March 15, 2006, 12:27:16 pm ---
yup, you're right, Xmen actually does the same. Either way though, there ARE games that put characters right on the screen, so I still say its a bad idea. Shift keys would work out much better.
rwhip41:
Just as an option...
Could you buy an IPAC 2 and hook it up to the IPAC 4? I'm pretty sure you can do that with IPACs, although I've never looked into it.
GoPodular.com:
mouse1
mouse2
mouse3
RayB:
GoPod beat me to it.
Hack a mouse.
