Main > Main Forum
Coin Counters
Pages: << < (7/7)
cabe:
you know, you could just print of a label with the original numbers on it, preserve that history (even if the guy who chopped the dynamo cab in half didn't!)
ppilot:
--- Quote from: Thenasty on March 16, 2006, 07:54:29 am ---check my page for connection diagram.Its a diagram for 2 or 4 connections to one Counter.
Could you elaborate on this diagram a little?  What are the diodes?  Where is the counter drawing power from?
Thank you.
Q*Bert_OP:
1n4004 will work just fine
Thargok:
--- Quote from: ppilot on March 18, 2006, 03:11:59 pm ---
Thank you.
The counter draws power from your ipac/keywiz/whatever/USB/etc.
ppilot:
--- Quote from: Thargok on March 19, 2006, 12:17:27 am ---
Thank you.
And what are the diodes?  If I just wire the positive wire on the coin counter to the ground on the credit switch, and the ground on the counter to the ground on the ipac, I get nothing :(
Pages: << < (7/7)
Go to full version
