Main > Main Forum
using old computers
miles2912:
--- Quote from: mrynit on March 06, 2006, 11:58:09 pm ---i have two old computers. P2 266mhz with 64MB 72pin ram & K6 AMD 400Mhz 128MB PC100 ram. the video cards i have are old ati RAGE 2 and 4 MB vram. what type of mame or emulators and FE could i use on them?
What I have done to see if the PC would play a game is to plug it in and try. You could have a few emulators up and working in 10 minutes if you know what you are doing.
Don
TOK:
Both those machines are fine for oldies. I found MAME at .3something and it ran all the golden age stuff great on a Pentium 133. Just use an old build and keep the fluff to a minimum and the early to mid 80's stuff will be fine.
SirPeale:
--- Quote from: zaphod on March 07, 2006, 08:02:37 am ---The 266 is plenty powerful for Vantage and ArcadeOS over DOS. I can run that on a P90 with 32MB RAM with full framerates.
This I know. VAntAGE has it's uses (I maintain the website) but these days I go for authenticity over speed, so I stick with Mame. Might require more pony-power, but it's more accurate.
USSEnterprise:
The only problems you may have with DOS is setting up config.sys, autoexec.bat, and the many drivers for various devices. I know I did at first
mrynit:
yeah drives for DOS could be a pain. how about win95 or 98? drives for that should be easier but then more CPU would goto OS.
