Main > Main Forum
Question on dual Act-Labs guns to support MAMEdev!!!!
Cananas:
Yes. Thank you very much, Derrick.
Tiger-Heli:
Just wanted to take a moment to say thanks as well.
P.S. (I remember when you were working on the 4-way code in MAME - the great stickymode debate).
Farmboy90:
So I have two LCD TopGuns and Acorns guncon driver. Do I need to do anything? Things work fine now. Are you saying I can "upgrade" to this patch and things will be better?
Derrick Renaud:
--- Quote from: Farmboy90 on March 10, 2006, 06:24:43 pm ---So I have two LCD TopGuns and Acorns guncon driver. Do I need to do anything? Things work fine now. Are you saying I can "upgrade" to this patch and things will be better?
Umm.... from the whatsnew.txt:
> 0.104u5
> Updated windows input code: [Derrick Renaud, Jake Stookey]
> * Now using RAWMOUSE mode if available. This means you can now use
> multiple mice in Windows XP. Lightgun support has not been
> changed yet.
aljupy:
--- Quote ---Umm.... from the whatsnew.txt:
> 0.104u5
> changed yet.
I would like to test mame 0.105 if 3 LightGuns can work at same time for that games like "REVOLUTION-X", where 3 players could play at same time ;D ;D :D
WOW!!!
