Author Topic: Building a star wars yoke...have a question  (Read 1417 times)
rbarr110
  • Last login:September 25, 2023, 04:02:41 pm
  • I already built my own arcade controls!
« on: March 01, 2006, 08:07:38 pm »
I searched and I believe the last post here tells me exactly what I am thinking, but I want to be sure.
http://forum.arcadecontrols.com/index.php?topic=45490.0
I have read through this    http://arcadecontrols.com/hosted/yoke/
for info on how to do it, and have been using Autocad to draft up the plans and making a few small changes.
Anyway, teh guide says use (2) 40 tooth gears and (2) 20 tooth gears.  I am assuming the tooth count isn't important, but that the 2:1 ratio is what is needed.
« Last Edit: March 04, 2006, 04:53:15 pm by rbarr110 »
Havok
  • Trade Count: (+17)
Re: Building a star wars yoke...have a question
« Reply #1 on: March 02, 2006, 12:34:04 am »
2:1 ratio should do fine. Make sure to post your project, I attempted to make one of these and gave up for a while: I can't cut wood worth crap. At least I have all the parts to make it when I finally get around to trying again. Must practice more with the scroll saw...
NoOne=NBA=
« Reply #2 on: March 02, 2006, 12:43:20 am »
Forget the scroll saw.
Draw your target line, rough cut the wood with a circular saw, and then sand it down to the line with either a belt sander, or a sanding attachment for your drill.
I usually end up having to come behind my jigsaw/bandsaw/scrollsaw with a sander anyway, due to blade deflection.
rbarr110
« Reply #3 on: March 02, 2006, 04:27:19 pm »
OK
« Last Edit: March 02, 2006, 04:31:47 pm by rbarr110 »
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #4 on: March 02, 2006, 11:09:12 pm »
I don't think there's 90 degrees of travel forward and back the originals.  There was a thread once where somebody measured it, but I'll be darned if I can remember where it is.  Anyone?
rbarr110
« Reply #5 on: March 03, 2006, 12:30:37 pm »
Ok- it probably isnt 90 degrees each way, becasue you would end up with nearly 360-degree movement.  But 45 seems to little, gives about 270-degrees, I made a quick sketch to show what 45-degrees looks like.  Maybe go to 60-degrees.....
« Last Edit: March 03, 2006, 12:39:30 pm by rbarr110 »
Havok
« Reply #6 on: March 03, 2006, 03:33:49 pm »
That might work. I would think though, with the windows calibration you could compensate for the difference. It may affect gameplay slightly, but should still be quite playable...
Kremmit
  • - AHOTW -
« Reply #7 on: March 03, 2006, 10:53:58 pm »
Oh, from your earlier post, I thought you were talking about the forward-and-back motion of the handles, used to aim in Star Wars.  Your pics make me think you're talking about the right-to-left motion of the steering instead.  That might be closer to 90.
There must be somebody with a real SW yoke that can take measurements for you.  I could try mine, but it's not from SW, and might not match.
rbarr110
« Reply #8 on: March 04, 2006, 02:22:37 pm »
In  my earlier post I was talking about the forward and back motion, I think I have that all hammerred out, was just looking for more knowledge on the x-axis rotation (left to right).
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #9 on: March 04, 2006, 07:36:20 pm »
There must be somebody with a real SW yoke that can take measurements for you...
i have an original SW yoke. it's 70 degrees.
to see my "Frankenpanel" and design notes, click here.
rbarr110
« Reply #10 on: March 05, 2006, 12:41:23 pm »
THANKS!
RobotronNut
« Reply #11 on: March 05, 2006, 06:09:19 pm »
just to be sure i don't miscommunicate: from the zero point, you can rotate it 70 degrees in each direction, so the full range of motion would be 140 degrees.
