Author Topic: Is it safe to just turn off the computer?  (Read 842 times)
gonzo90017
« on: March 01, 2006, 06:36:36 pm »
I'm about to build a bartop and would like to turn everything off at the same time so I was wondering if it's safe to just cut the power. Keep in mind a keyboard won't be an option and this will be a gaming only cabinet.  It won't be used for anything else. And remember I would like to turn off everything at the same time, monitor, marquee, speakers, and pc.
dax
  • Last login:August 17, 2006, 02:13:08 pm
Re: Is it safe to just turn off the computer?
« Reply #1 on: March 01, 2006, 08:40:32 pm »
Under DOS, I don't see a problem with this.  Under Windows, yes.
Necro
  • Last login:November 29, 2022, 08:22:22 pm
« Reply #2 on: March 01, 2006, 09:16:40 pm »
Not a chance.  It may work fine for awhile, but eventually somethings going to screw up.  That and your going to have a ton of temp files build up that aren't cleaned out correctly.
Best bet would be have a button setup that just shuts down windows and have everything else...uhm...wired to a switch that cuts power to everything else.
Yeah...thats it. :P
gonzo90017
« Reply #3 on: March 01, 2006, 09:35:07 pm »
Thanks guys ;D I'm planning on using windows so oh well. I know Mamewah is able to shut down on exit but what about Game Launcher?
Kayser
  • Last login:August 23, 2006, 03:48:45 am
« Reply #4 on: March 03, 2006, 12:34:42 am »
I was wondering if you can program your computer to shutdown by pressing 2 keystrokes at the same time.
i know you can set up your computer to shutdown by pressing CTRL+ALT+any key,but what i want is just 2 keystrokes.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #5 on: March 03, 2006, 12:42:10 am »
Well, you can extend your computer power button to a plain microswitch button somewhere on the back of the cabinet and that would safely shut the computer down.  Having the PC tied into a smartstrip power strip, that would shut everything else off and turn everything on.  I have a Happs triangle button mounted on the front of my current cabinet that does just that.  Here is a picture of the button.  It worked out perfectly:
Here is a pic of the smartstrip:
« Last Edit: March 03, 2006, 12:48:54 am by mccoy178 »
gonzo90017
« Reply #6 on: March 03, 2006, 01:23:42 am »
So as soon as I turned my computer off smartstrip would take care of shutting everything else off automatically?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #7 on: March 03, 2006, 01:46:34 am »
Yes, it is God's gift to our hobby.  It glows when it arrives.  The doorbell rings and no one is there, just this wonderful invention sitting on the porch hovering.
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #8 on: March 03, 2006, 02:39:14 am »
The mini power minder is great too. It's about 15 bucks and does the same thing. I use it and Mamewah.
The motherboard is set to start up by the keyboard. So, I can hit any arcade control to start the arcade, and use the shutdown option in mamewah to power everything down.
Couldnt be easier or more convenient.
