Main > Project Announcements
"The Varsity Club" Dual Monitor Arcade *Reconstruction has begun* 12/29/09
mccoy178:
Today I accomplished a few tedious things that I have been wanting to finish. I figured out what to do with the volume controls, made a cabinet friendly harddrive holder, and I transfered all my software files to the new computer. Here is a pictorial of how I mounted the volume controls.
I decided to put them on the bottom of the cp box. I also didn't like the looks of the factory box it came in. I decided that plexiglass would be an easy option. Here are the supplies used:
I decased the controls and drew the hole template onto the plexiglass:
I then uses standard drill bits to drill the holes:
Here is a picture of the controller sitting loose in the plexi. I was happy with the looks:
Once I decided that it looked okay and would function, I had to figure out where to locate it on the cp. I choose the 1P side and just far enough in that you would have to look for it to find it:
I routed out the area and superglued the plexi into the spot:
Here is to give some perspective of its location. I also drilled out a spot for the Shazaam button on the front left side of the cp box:
I also painted the controls black to match the cabinet. All in all, I'm very happy with the results. Once I get the box painted, I'll show some completed pics:
mccoy178:
If I had one major ---smurf--- from my first cabinet, it was how ridiculously hard it was to mess with the computer and especially the harddrives when it was decased. I've been thinking about a solution and I used $2 in plexi to find it. Here is a tutorial on how I made it. There are no holes drilled yet, but it should be obvious how the shelving works. I tried to leave as much space as possible for cooling. Let me know what you guys think on this one as I don't want to burn up the goods. I'm contemplating throwing a little fan on it, but I don't think it's necessary.
Okay, I just measured a Harddrive and that is how I made my cuts. I wanted it big enough for four drives and I just cut it as I went. Here are the supplies used:
I only exposed the parts I was glueing and used that as a rough guide:
I glued and clamped down the shelves for both sides:
Here is one half complete:
I just glued on a top and bottom and a couple support pieces. All in all, it took a little over an hour. I also added a long piece on one side for mounting purposes. I plan to paint this black tomorrow. More pics to come:
markrvp:
Don't paint it black - it looks badass clear like that.
arcadegamenut:
Last cabinet you'll ever build eh? What if I offered a collection of dead presidents?
mccoy178:
You'd have one dead builder from insanity! :dizzy:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
