Author Topic: Dos 6.22 setup question  (Read 1060 times)
AlexC
  • Last login:May 06, 2012, 05:18:05 pm
  • "Beware, I live!"
« on: February 26, 2006, 01:27:26 pm »
Got a CF that I setup with DOS 6.22, MAME .36,and Gamelauncher. It works ok but it's booting up a little slow (from power-up).
I've seen some sites that have Autoexec and Config examples of what I should have, but those are people are using DOS under WIn98 so not sure I can use them for my setup.
Here's mine as of now:
Config :
DEVICE=C:\DOS\HIMEM.SYS
DOS=HIGH,UMB
FILES=40
BUFFERS=40
Autoexec:
@ECHO OFF
SET CTCM=C:\CTCM
C:\CTCM\CTCU /S
C:\DOS\SMARTDRV.EXE /X
C:DOS\FASTVID 011 8 D1000000
CLS
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
SET BLASTER=A220 I7 D1 T2
CLS
CD GLAUNCH
GLAUNCH
Let me know if there's anything I should change or add to make a difference. The computer is an old one, a HP 333mhz 64 ram (I think) no cdrom no floppy no mouse.
The games run fine and load fine, it just takes too long for the computer to load into Gamelauncher.
« Last Edit: March 01, 2006, 10:17:29 am by AlexC »
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: Dos 6.22 setup question
« Reply #1 on: February 26, 2006, 02:14:50 pm »
I'd remove the CD-Rom driver, since you won't be using it that often once everything is set up (unless you're using it to store roms or something). If you do need to use the cd-rom at some point you could always set it up with a seperate bat.
« Last Edit: February 26, 2006, 02:57:37 pm by JoyMonkey »
AlexC
  • "Beware, I live!"
« Reply #2 on: February 26, 2006, 02:57:37 pm »
Oops I copied the wrong config and autoexec files  :P
Here's what I'm using :
Config :
DOS=HIGH,UMB
FILES=40
BUFFERS=40
Autoexec:
@ECHO OFF
SET CTCM=C:\CTCM
C:\CTCM\CTCU /S
CLS
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
CLS
CD GLAUNCH
GLAUNCH
Also xmsdsk, is that a command that I change in the autoexec or a program I have to download?
AlexC
  • "Beware, I live!"
« Reply #3 on: March 01, 2006, 11:09:55 am »
Shameless bump  ;D
Also how do you edit the game names in Gamelauncher to not show the info on parenthesis ??   --- example : Moon Patrol (Williams)
JLR2000
  • Last login:February 18, 2021, 02:49:16 pm
  • There is NO Sanctuary...
    • WWW
« Reply #4 on: March 02, 2006, 04:43:29 pm »
Alex-
Can't help you with GL, but here's a great resource for setting up DOS for running mame:
http://www.mameworld.net/dosmame/
good luck.
JoyMonkey
    • JoyMonkey.com
« Reply #5 on: March 03, 2006, 02:04:07 pm »
...how do you edit the game names in Gamelauncher to not show the info on parenthesis ??   --- example : Moon Patrol (Williams)
Edit the MAP file for whatever emulator you're using, it should contain the rom names, followed by what you'd like that rom to be displayed as.
For example, open up mame.map and edit the mpatrolw line so it reads:
Code: [Select]
mpatrolw "Moon Patrol"
AlexC
  • "Beware, I live!"
« Reply #6 on: March 03, 2006, 07:02:53 pm »
Awesome  :D, that fixed them.
Thanks JoyMonkey, you always have the answer to these oddball questions.
