Author Topic: Question about a cabinet on/off switch  (Read 920 times)
Wir3d
  • Last login:October 31, 2007, 04:41:45 pm
  • Huh?
« on: February 26, 2006, 04:50:42 am »
Hi,
I,ve just aquired a dedicated nba jam arcade and the cabinet is missing an on/off switch.
How many amps should the switch be......3a 125v......or 6a 125v?    or does it matter.
tommy
Re: Question about a cabinet on/off switch
« Reply #1 on: February 26, 2006, 05:08:52 am »
I'm not totaly sure but are you sure the switch is missing?
Maybe the switch is in near the coin door and you didn't see it?
Wir3d
  • Huh?
« Reply #2 on: February 26, 2006, 05:19:22 am »
nope, the switch is missing ive searched throughout the whole cab and its not there, and there is a small hole cut out of the top rear cab where the switch goes, so i know for sure the switch is missing
Wir3d
  • Huh?
« Reply #3 on: February 26, 2006, 04:17:22 pm »
this question cant be that hard to answer can it?
woodygjw
  • Last login:August 26, 2012, 09:33:59 pm
« Reply #4 on: February 26, 2006, 05:32:01 pm »
Go with the 6 amp, 3 would probably be ok.  Most likely the higher the amperage on the switch, the better it would be.  Or check the back of the cabinet for a rating plate, probably near the power cord to see how much current the thing draws.
woody
Q*Bert_OP
  • Oh yes, we did!
« Reply #5 on: February 26, 2006, 06:16:02 pm »
Fine your cabinet will be, with a 10 Amp rated switch.  :laugh:
Wir3d
  • Huh?
« Reply #6 on: February 26, 2006, 08:00:39 pm »
cool, thanks for the help
