Author Topic: Got a counter top arcade. It was gutted out. Need some suggestions  (Read 860 times)
janey
  • Last login:August 06, 2016, 02:36:23 pm
  • I want to build my own MAME / Hyperspin cab
 on monitor, and  how to do the  wiring ..
 I want to rebuild this counterTop, to a MAME  and what kind of monitor should i put in there . I
 believe a 13" fits in there .  and how do i do the wiring??/
   Can you guys and gals tell me what would u do ? and where can i read up on building a small mame .
http://i21.photobucket.com/albums/b267/janey6152/100_1662.jpg
http://i21.photobucket.com/albums/b267/janey6152/100_1652.jpg
« Last Edit: February 25, 2006, 03:27:21 pm by janey »
APFelon
  • Last login:May 09, 2023, 08:10:35 pm
Re: Got a counter top arcade. It was gutted out. Need some suggestions
« Reply #1 on: February 25, 2006, 07:17:21 pm »
If I had that cab, I'd buy a 13" LCD screen for the front and a mobo for the back. Hack a Sidewinder for the controls. Wiring would be a breeze.
APf
janey
« Reply #2 on: February 26, 2006, 12:44:32 pm »
OK will do , but whats
a Sidewinder
APFelon
« Reply #3 on: February 26, 2006, 01:00:04 pm »
Sidewinder is a control pad by Microsoft. It has nice solderable holes on the PCB and is USB ready, so it'll be a cinch to hack. The flat screen monitor can plug right in to a VGA card.
You won't have to fool around with JPACs or Arcade VGA cards this way. Just a little drilling, and wham, you have a killer bartop game.
Good luck, and let us know how it goes!
APf
janey
« Reply #4 on: February 26, 2006, 01:16:51 pm »
Hi, Apf
 Thanks for helping.  can u direct me to which one ? I went to ebay but i want to make sure i get the right one. cause i see a few different ones..
 thanks
again ..
janey
APFelon
« Reply #5 on: February 26, 2006, 01:37:26 pm »
http://cgi.ebay.com/Microsoft-Sidewinder-Game-Pad_W0QQitemZ8768888414QQcategoryZ74943QQrdZ1QQcmdZViewItem
This is the type I used before I built a cabinet. I thought I'd have to scrape contacts, etc. but I was able to solder wires directly in to clearly marked points on the board itself. I then screwed the board to the bottom of my control panel and it worked like a peach.
Before I discovered the JPAC, this was the route I was going to use on my cab (the advantage the JPAC has is that I could plug it in to the existing JAMMA harness already in my cabinet). It is just as responsive as anything out there.
Good luck!
APf
