May 08, 2024, 01:38:27 pm
Go with the i-pac. I just got mine in the mail today. I dont know anything about the other one tho.
OK, so there are no disadvantages over one or the other? What about for trackballs and spinners? I will have two trackballs and probably one but maybe two spinners? Optipac will work for that correct?
I went with a grilled cheese. I'm having some issues with it but it sure smells yummy.
Yes, there is a 10 pin header with three 5v taps.
Quote from: markrvp on February 23, 2006, 07:29:29 pmYes, there is a 10 pin header with three 5v taps.Ok cool thanks... So in order to use the Perfect's with the Mini Pac must I have the Mini Pac w/ the optional Optical inputs (69$ one), or is that only used for the trackball/spinner, and a Mini Pac Standard will work?Thanks
It is my understanding that there are no differences in the Minipac boards. The difference is the harness which either does or does not have the connections for the optical devices. If anybody can confirm this I would appreciate it.
