Author Topic: Sound-Activated Cathode Lighting AC (non-PC powered)  (Read 1357 times)
MiahXGaming
  • Last login:May 26, 2016, 02:42:21 pm
  • Legend
    • X-Arcade
« on: February 23, 2006, 11:50:26 am »
Does anyone know of a way to get sound activated lighting that runs off of AC power rather than PC powered?
For example this module works on PC power to make cathodes sound activated: http://www.xoxide.com/cocasoackit.html
I want the same, but without using a PC power supply (AC outlet powered).
Do something similar to DDR machines.
jimmah
  • Last login:August 29, 2013, 10:52:32 am
Re: Sound-Activated Cathode Lighting AC (non-PC powered)
« Reply #1 on: February 23, 2006, 12:01:29 pm »
I don't know the answer for you but my question is why not us a PC PS? you can get an older next to nothing. I used a freebie from a shop to power the fans in my cab.
MiahXGaming
  • Legend
    • X-Arcade
« Reply #2 on: February 23, 2006, 12:11:30 pm »
Because...
rackoon
  • Last login:July 28, 2023, 02:29:36 pm
  • I EAT PENCILS!
« Reply #3 on: February 23, 2006, 03:39:33 pm »
What the hell is a cathode? Are they like LED's?  Do they last a long time like LED's?
They treated me like an animal and that's what I became.
Buddabing
« Reply #4 on: February 23, 2006, 05:13:57 pm »
Well, you could use a standard arcade switching power supply. They have the same +5 and +12 voltages that PC power supplies deliver to the molex connections.
Please read the wiki!
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #5 on: February 23, 2006, 11:53:47 pm »
Get a wall wart that outputs 12v DC (or 5v if that's what you want) and wire it up.
-- Chad Tower
quarterback
« Reply #6 on: February 23, 2006, 11:56:15 pm »
Or get this here
The picture looks odd to me, but the short description sounds right.
Adapter / Transformer converts 110V AC to 12V DC 5.25" & 3.5" Molex connectors.
Item Details
Power Adapter to Convert AC Power to Molex Power Connector
-- Chad Tower
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #7 on: February 24, 2006, 12:35:32 am »
Its kinda like neon, but generates no/little heat
MiahXGaming
  • Legend
    • X-Arcade
« Reply #8 on: February 24, 2006, 04:20:31 pm »
Or get this here
Item Details
That sounds like the ticket, kudos!
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
« Reply #9 on: February 24, 2006, 07:29:48 pm »
You would need a step down transformer, that would likely cost about the same as a 12V power supply. I just ran my Cold Cathode off of the 12V on the arcade PS.
quarterback
« Reply #10 on: March 21, 2006, 10:38:59 pm »
Just as a followup to this previous suggestion I made.  I recently bought an $12 USB->IDE connector (the kind of thing you use to hook a hard drive up to a USB port, but without an external enclosure) and it came with a power supply (of course) so you could power up your IDE drive.
The power supply is a 3-prong (grounded) wall plug that goes to a box (transformer) and has a molex connector coming out. You're supposed to plug that molex connector into your IDE drive BUT what it REALLY is is a quick/easy and relatively cheap way to get both 5v and 12v DC from your 120V AC wall socket.   And, according to my multimeter, it's pretty close.... much closer than my multi-output wallwart, which is WAYYYY off on the voltage.
Anyway, my point is, for $11 you can get a 'replacement' for your PC Power Supply if you need to run a number of PC-type accessories (like cold cathodes, LEDs, fans etc) but your PC power supply doesn't have enough plugs or is just inconveniently located or whatever.
Here's a link to what I bought.  And a picture of the adapter:
Or get this here
Item Details
-- Chad Tower
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #11 on: March 22, 2006, 03:33:12 am »
That looks like a pretty cool little gadget. Did you actually buy your converter from that website? I'm always a bit hesitant to start buying things from random computer websites.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #12 on: March 22, 2006, 06:41:17 am »
Your best bet here is to try Disco and DJ equipment suppliers.... You can get cheap sound to light controlers from them. Those will drive your Cathodes.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
quarterback
« Reply #14 on: March 22, 2006, 11:51:19 am »
I did buy from geeks.com    Computer Geeks (aka geeks.com) is fully legit.  I've bought a number of things from them over the last 5 or 6 years.
Also, there are 10% off coupon codes available.  Google should bring them up.
-- Chad Tower
