| Main > Software Forum |
| GBA in mamewah |
| << < (2/2) |
| Doc Thirst:
Yep, I think I have mamewah config'ed correctly. Im thinking it's somewhere in the vba ini file... [preferences] windowX=0 windowY=0 language=1 languageName= frameSkip=2 gbFrameSkip=0 autoFrameSkip=0 vsync=0 synchronize=1 stretch=0 video=6 defaultVideoDriver=1 fsWidth=800 fsHeight=600 fsColorDepth=16 renderMethod=1 useBios=0 skipBios=0 soundEnable=783 soundOff=0 soundQuality=2 soundEcho=0 soundLowPass=0 soundReverse=0 soundVolume=0 ddrawEmulationOnly=0 ddrawUseVideoMemory=0 tripleBuffering=1 d3dFilter=0 glFilter=0 glType=0 filter=0 disableMMX=0 disableStatus=0 showSpeed=1 showSpeedTransparent=1 gbPrinter=0 pauseWhenInactive=1 useOldSync=0 captureFormat=0 removeIntros=0 recentFreeze=0 autoIPS=1 disableSfx=0 saveType=0 enhancedDetection=1 ifbType=0 flashSize=65536 agbPrint=0 rtcEnabled=0 autoHideMenu=0 skinEnabled=0 skinName= borderOn=0 borderAutomatic=0 emulatorType=1 I'm gonna start checking em one by one. I'll let you know if I find it. |
| Fat_Trucker:
Try changing that emulator type to 0 right at the bottom of that ini. Don't know if it will make a difference but its the only line thats different to the ini im using. Failing that its got to be a command line problem as afaik VBA doesn't have an option to rotate the screen. |
| Doc Thirst:
On a whim I deleted the emu ini (not the mamewah one) and ran it again. Didn't create a new ini, nor did it error out, so I guess the issue might be in the command line or mamewah after all, still looking. I'll be sure to post a resolution when I find it for prosperity. |
| Doc Thirst:
Borderline moron here. There is a cfg file for the emu. Tracking it down now. |
| Doc Thirst:
OK here you go, this is the SDL release on the screenshot archive: VisualBoyAdvance.cfg You are looking for a line: # Video setting. 0=1x, 1=2x, 2=3x, 3=4x. video=0 Anything but 0 will rotate the screen 90 degrees. Hopefully this will save someone some time in the future. Thanks for those who helped me track this down! |
| Navigation |
| Message Index |
| Previous page |
