Main > Main Forum
720 degrees
Pages: << < (8/16) > >>
jerryjanis:
Config menu(tab key)->Controls(this game):
1) set Track_y to the button/switch you want to use for calibrating
Config menu->Analog controls:
1) Play with the track_x sensitivity (for my joystick I set it to 50%) for your spinner (assuming you have one) - try to set it up so that when you spin the spinner once, the skateboarder spins exactly once.
2) Set the track_y sensitivity for the calibration spinner (I don't think it can hurt to put it to the maximum) and set the key/joy speed (I don't know what values would work best).
SirPoonga:
--- Quote from: jerryjanis on March 03, 2003, 05:38:09 pm ---Config menu(tab key)->Controls(this game):
Ok, downloaded your exe.  Let me get this straight, if my character isn;t pointing straight north, and I assaign a key to track_y, when I press track_y he should slowly calibrate north?   Hmmm, not working for me.
u_rebelscum:
BTW, I included jerryjanis code in Mame:Analog+ 0.65.2.  Thanks jerryjanis!
jerryjanis:
--- Quote from: SirPoonga on March 03, 2003, 05:53:08 pm ---Ok, downloaded your exe.  Let me get this straight, if my character isn;t pointing straight north, and I assaign a key to track_y, when I press track_y he should slowly calibrate north?   Hmmm, not working for me.
You need to go into the analog settings (by pressing tab and selecting 'analog controls') and juice up the track y sensitivity (I set mine to the max: 255%) and the track y key/joy speed (I set mine to 10).  I made the default setting for track y to the minimum in order to minimize the effect it has on somebody who is using a regular mouse.  If you are the rare person who actually has a working joystick of some kind then you need to increase the values manually.
jerryjanis:
--- Quote from: u_rebelscum on March 03, 2003, 09:53:38 pm ---BTW, I included jerryjanis code in Mame:Analog+ 0.65.2.  Thanks jerryjanis!
Hey, that's great (1 less special version of Mame to worry about!).  Thanks!
Go to full version
