Author Topic: Mamewah Help Needed With List Options!  (Read 1447 times)
M.A.M.E Power
  • Last login:February 06, 2007, 04:25:59 pm
  • There Are So Many Games!
« on: February 14, 2006, 10:34:02 am »
Ok Mamewah is set up and working fine - but for some reason when I attempt to do a filtered list it is creating a filtered down list of the main roms (seems without clones) and gives me no options to customize (i.e light gun games & year filters etc).
I know this option is available as it was working on my previous computer. My new mame computer is set up but for some reason it does not produce any options. I am running mamewah 1.61 version with buddamame's 1.02 build version.
Where am I going wrong?
Lea
« Last Edit: February 14, 2006, 04:30:07 pm by M.A.M.E Power »
M.A.M.E Power
Re: Mamewah Help Needed With List Options!
« Reply #1 on: February 14, 2006, 02:13:26 pm »
/bump
« Reply #2 on: February 15, 2006, 04:41:56 am »
Make sure you are using 'list_generation_method rom_folder_vs_listxml',
Generate the 'main' list,
Make sure you have a custom list selected (not the main one),
Go into Games List Options > Generate Filtered List > etc...
M.A.M.E Power
« Reply #3 on: February 15, 2006, 07:34:48 am »
Thanks for your reply Minwah.
I have two hard disk drives and currently have my roms on the D:\ drive seperately.
The mame folder which contains everything else (mame.exe) etc is on the C:\ how do i tell mamewah where the xml folder is (where is the default location that mamewah will look?).
Do I need to have the rom folder in with the mame folder for it to work?
Lea
« Last Edit: February 15, 2006, 07:47:52 am by M.A.M.E Power »
« Reply #4 on: February 15, 2006, 10:23:17 am »
You need to set 'rom_path' accordingly in your (mamewah) emulator ini file.
No, but you must setup MAME properly so it knows where your roms  are (this is totally independant of FE).  ie, you need to set your 'rompath' in \mame\mame.ini.
M.A.M.E Power
« Reply #5 on: February 15, 2006, 11:56:01 am »
Ok here is my emulator ini file:
### 01mame.ini (mamewah v1.61) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  d:\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                                  c:\mame build\mame\catver\catver.ini
### Execution Settings ###
emulator_executable                       c:\mame build\mame\mame.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      d:\snap
artwork_2_image_path                      d:\marquees
artwork_3_image_path                      d:\artwork
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path                        d:/mame/movies
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                movie
movie_path                                d:\mame\movies
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              1
I created a listxml - I just can't seem to figure out what I am doing wrong - still cannot filter the lists with any different inputs.
I can play the games so i know my paths are correct, just cannot filter the lists.
All help is greatful
Lea
« Last Edit: February 15, 2006, 11:59:10 am by M.A.M.E Power »
M.A.M.E Power
« Reply #6 on: February 16, 2006, 10:41:20 am »
Have been trying to figure this out for ages and I am now getting frustrated. I am using budda's latest build and Mamewah 1.61 all my rom paths are set up as well as artwork etc and all work fine.
I created a listxml using the command line - I have it set-up the emulator.ini file as rom_folder_vs_listxml, but when I load mamewah I cannot filter the lists at all.
I cannot see what I am doing wrong.
Please help :'(
Lea
« Reply #7 on: February 16, 2006, 11:27:54 am »
I don't know what you mean by 'created a listxml'...you don't need to do anything like that - use Mamewah to generate your games list.
Go back and check my first reply - follow those instructions as that is all you have to do.  You don't say exactly why you can't filter the lists, so I assume you probably don't have a custom list selected (you cannot filter the main 'All Games' list).
Edit: btw your ini file looks absolutely fine, so don't change anything there.
M.A.M.E Power
« Reply #8 on: February 16, 2006, 12:03:03 pm »
Ok then, is it because I am using budda's build and not the main mame build (uncompiled version). I select a list (Fighting Games) go to create list (generate filtered list).
When I click on the filtered list option nothing happens it creates a list of games which I think are the filtered down list of the main list (display clones only if better than parent, i think) it gives me 3000 odd roms?
