Author Topic: Please take a look at my CP  (Read 1281 times)
dheck
  • Last login:December 27, 2022, 11:57:26 am
« on: February 10, 2006, 10:39:37 am »
This is my design for a 4 player CP.  It is a 2 story CP.  The second story is only there if I decide I want to add a spinner or a flight stick later down the road.  Do you guys think this is a user friendly CP?  I gave some rough dimensions.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
Re: Please take a look at my CP
« Reply #1 on: February 10, 2006, 10:41:20 am »
What trackball games will you be playing?  If you have to roll the ball forward quickly or with much force, your fingers may slam into the 2nd tier.
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #2 on: February 10, 2006, 10:41:38 am »
No need for that many buttons for players 3 and 4...  I don't think any 4 player games use that many buttons.
But it looks nice.
dheck
« Reply #3 on: February 10, 2006, 10:43:43 am »
I will use the trackball for mostly the mouse.  I know some of my buddies like to play Golden Tee.  They may have to deal with it.  I will move it down some and see what it looks like.  I see what you are saying though.
Hoopz
« Reply #4 on: February 10, 2006, 10:46:50 am »
You'll probably be told by a lot of people to do a mock up and see what you like/dont like.  It really is the best way to see if your idea works well and what may need to be changed.
Lemme be the first...do a mock up and see what you like/dont like!  ;D
dheck
« Reply #5 on: February 10, 2006, 10:49:13 am »
My other concern is the angle of the 3 and 4 players being able to see the screen correctly.
WwonderLlama
  • Last login:July 01, 2009, 03:56:56 pm
  • I _am_ a llama!
    • MAME gallery (working link!)
« Reply #6 on: February 10, 2006, 11:14:33 am »
It looks like you have the flanking players (P3/P4) joysticks at an angle.  I asked about this when planning my CP, and got a resounding "Don't do it that way." ;)
Check this thread: http://forum.arcadecontrols.com/index.php?topic=22806.0  (especially the last few posts with the pictures)
(All of my links are broken, but the others seem to be good)
« Last Edit: February 10, 2006, 11:18:14 am by WwonderLlama »
At it once again.
dheck
« Reply #7 on: February 10, 2006, 12:56:32 pm »
When I originall drew it I had them all facing the screen.  Then I printed out the CP full size and stood around it trying to get a feel and it just felt awkward with them not rotated.  But without actually playing a game like this I can't be sure.  If I rotate them back so it faces the screen, should I move the buttons around as well?  With the sticks facing forward the button placement felt too high.  It's hard to explain.  :(
dheck
« Reply #8 on: February 10, 2006, 12:59:53 pm »
Here they are rotated.  But now the button placement looks off.  Like the stick is too high.  Like if you are hittin UP on the joystick you are too close to the first set of buttons.
« Last Edit: February 10, 2006, 01:02:29 pm by dheck »
Hoopz
« Reply #9 on: February 10, 2006, 01:02:49 pm »
Never mind.  I re-read your post and realized what you meant.  My original response had nothing to do with what you meant. My bad....  ::)
« Last Edit: February 10, 2006, 01:05:13 pm by HooPZ »
dheck
« Reply #10 on: February 10, 2006, 01:08:30 pm »
Sarcasm much?
It's just easier for me to brain strom and get a good idea on paper even before the mock up.  8)
Hoopz
« Reply #11 on: February 10, 2006, 01:31:42 pm »
Sarcasm much?
No sarcasm.  I originally answered something that you didnt ask.  Thats why I edited it out.
Dagg
  • Last login:June 05, 2017, 04:23:59 pm
« Reply #12 on: February 10, 2006, 01:38:10 pm »
If he's running console Emulators its not to many buttons, I find alot of folks here are always to fast to comment on that point.
dheck
« Reply #13 on: February 10, 2006, 01:41:49 pm »
I came up with this one.  I don't like it as much but I think it's a little more playable.
WwonderLlama
  • I _am_ a llama!
« Reply #14 on: February 10, 2006, 01:50:54 pm »
I know what you mean. I thought it seemed an odd layout as well.  I eventually mounted all 4 joysticks' UP facing the top of the CP (as the people on the board suggested) and playtested it with 3 other friends.  They didn't have a problem with it, even though my 3/4P are at rather sharp angles.
My artwork highlights the positioning of the buttons to joysticks (they're all uniform).  It's not often that P3/4 are used, but when they are, I've had noone complain.  I'd personally not change your distances from the joysticks/buttons, but do whatever feels right for your cab.
Another idea would be to get 2 people both playing a game (P1 & P3) and see what they think. You're likely to be much more critical of the placement than others are.  If the "All joysticks UP" layout seems natural to someone "off the street", then you're good to go.
Also, if you're thinking the buttons look "off" because of your diagram, try removing the rectangles from around the joysticks... You won't be seeing them on your final CP, will you?  Also, P3 would be standing at an angle from the CP, so his left arm would be perpendicular to his button-rows, so his arm shouldn't ever be interfering with his button-smashing hand.
At it once again.
WwonderLlama
  • I _am_ a llama!
« Reply #15 on: February 10, 2006, 01:53:00 pm »
I personally stayed away from that sort of layout for one reason: broad-shouldered players.  If your cab will be played by mainly teenage (stick-figure) girls, you'll likely never have a problem. :)
But, if you'll have larger guys (say, 6'1"), they may be jostling each other while trying to play.
Elbow/shoulder room = good. :)
At it once again.
Clonedsheep
  • Last login:August 03, 2021, 07:11:08 pm
« Reply #16 on: February 10, 2006, 02:06:28 pm »
I may be reading it wrong but my only question is that with that U cut control panel, are you making the players smash there faces to the monitor to play? If that is the case. Then go with less of an deep cut. I do like the style.
The king of 1/2 done projects
WwonderLlama
  • I _am_ a llama!
« Reply #17 on: February 10, 2006, 02:15:03 pm »
The monitor isn't shown in his diagram, the 6.5" deep, 2'-5 wide area is part of the control panel (where a second-tier might be?).  So, it looks like the center of the trackball is about 1 ft. from the monitor.. should be enough for comfort.
At it once again.
dheck
« Reply #18 on: February 10, 2006, 02:15:32 pm »
You pretty much hit every concern I had.  I feel a lot better now.  I will mock it up just to make sure.  I did not like the last design so I am glad you gave me some insight that my original just might work after all.
dheck
« Reply #19 on: February 10, 2006, 02:16:46 pm »
Yes, sorry.  Here is my cab design if it helps clear things up.
WwonderLlama
  • I _am_ a llama!
« Reply #20 on: February 10, 2006, 02:42:44 pm »
Happy to help. :)  I'm just glad that other people can learn (or draw comfort) from my mistakes. ;)
At it once again.
