Author Topic: Will someone please post the Odyssey2 emulator OME2V1.16 ... thanks  (Read 1160 times)
unclet
I would like v1.16 (since a Mamewah hack exists for v1.16) and the only version at the O2EM site is v1.17 ...... which I doubt the hack will work on ...
If it is too big to post here, then please ZIP it and send it to me at emailAddrRemoved
« Last Edit: February 22, 2008, 09:48:08 am by unclet »
jcrouse
    • CPViewer
Re: Will someone please post the Odyssey2 emulator OME2V1.16 ... thanks
« Reply #1 on: February 09, 2006, 02:54:52 pm »
You can download a hacked version here:
http://home.comcast.net/~cpviewer/odyssey2.htm
It is fully cabinet compatable. Read the included docs.
Good Luck,
John
unclet
« Reply #2 on: February 09, 2006, 03:01:54 pm »
Yes, that is the hacked EXE ..... the readme file in there states I first need to install O2EM v1.16 for windows, then overwrite the EXE file with the one supplied in the hack.   I have the hack already, just wanted to get the full v1.16 application now to install first.
« Last Edit: February 09, 2006, 03:11:41 pm by unclet »
jcrouse
    • CPViewer
« Reply #3 on: February 09, 2006, 03:11:15 pm »
Sorry. I will look when I get home. Worst case, I'm sure I can zip up myo2em folder (it will be the original files / then hacked) and it should work fine. Looks like I need to get 1.17 hacked. :)
John
unclet
« Reply #4 on: February 09, 2006, 03:12:12 pm »
Getting a v1.17 hack would even be better....
« Last Edit: February 09, 2006, 03:15:48 pm by unclet »
jcrouse
    • CPViewer
« Reply #5 on: February 09, 2006, 04:27:38 pm »
Until then, send me an email to the address on the site I mentioned above.
John
unclet
« Reply #6 on: February 09, 2006, 04:30:42 pm »
John
Done
mjc0505
  • Last login:July 16, 2007, 10:02:11 am
« Reply #7 on: February 09, 2006, 04:34:04 pm »
Looks like you can get it here:
http://prdownloads.sourceforge.net/o2em
unclet
« Reply #8 on: February 09, 2006, 04:37:20 pm »
Perfect .... thanks
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #9 on: February 10, 2006, 09:13:11 am »
Ah, the Odyssey2..  I've still got mine in my basement.. Need to hook it up again..  :)
