Author Topic: My idea  (Read 1083 times)
Gradius
  • Last login:February 04, 2008, 03:10:49 pm
My idea
« on: January 29, 2006, 11:06:09 am »
I've designed this for a friend of mine. I have something similar already working, but wider and with a bigger tv. What do you think? Above all, it's practical and comfortable. The tv can be rotated manually and you can move or remove the control panel (there's room for a mouse pad). There's place for a couple of speakers too. The pc tower and the subwoofer will go below. The holes are for guiding the cables through. The piece in the middle is intended to make the cabinet stronger and to add stiffness to the control panel stand (using that metal piece you see). The height of the cabinet is the minimum possible (60cm) and the angle for the tv is 30
shodokan123
  • Last login:October 14, 2007, 01:57:20 am
  • Fighting Game Addict
Re: My idea
« Reply #1 on: January 29, 2006, 01:53:39 pm »
looks good imo
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
Re: My idea
« Reply #2 on: January 29, 2006, 02:18:28 pm »
I think that's really cool.
My problem is that I'm a maniac about things looking like TV's, so I'd have to make a top and sides that fully surround it (making monitor rotation a hassle).
Thinking about that, I just had another idea... I have a Samsung LCD monitor that you can just spin on its stand to rotate, plus it pivots. You could cut the size of your machine way down with that and still have monitor rotation. Not copying the form factor of a regular arcade machine sure opens up the options!  ;D
Gradius
Re: My idea
« Reply #3 on: January 30, 2006, 02:40:24 am »
What I've done for hiding the tv is a bezel, marquee or whatever it's called. It's a squared piece of pvc (5mm) with a squared hole of the size of the screen. It's covered with black vynil. It only hides the front of the tv, but it's enough, because that is what you see. When you rotate the tv, you just take this and rotate it too.
« Last Edit: January 30, 2006, 02:44:54 am by Gradius »
Lilwolf
Re: My idea
« Reply #4 on: January 30, 2006, 07:48:17 am »
I kind of like the idea...
But a few things
1st, its an ergonomic nightmare.  Your neck will probably hurt after a bit.  look at the guys sitting position.  he will be looking down for long periods of time.  Raise it up some and a bit less of an angle will help I think... But you should be able to prototype the tv and the mounting tray very easy with some boxes ect and see.  But you are supposed to look straight ahead to see the top 3/4 of the monitor or so.  So your head looks a bit down, but not that much.
second.  you will want to be able to clamp that controller on somehow.  Having it loose kinda stinks.  Whats great about a cabinet is that the controls are locked down firm and you don't have to worry about it moving.
third.  You will want to make sure that the table is at keyboard height.  No reason it couldn't be a computer workstation when not in use..  I pretty cool one at that.
fourth...  Consider if you can move the monitor up somehow so you can use it as a TV from across the room.  Heck, do this and if you don't have a control panels yet, you can go with two wireless xbox controllers (goto consoles forum to see the one I got... easy hack and fits most arcade buttons and some joysticks).  Then you can use it from the couch if you want to lay back.
fifth....  Is there one?  You might consider if you want to go with building a real arcade cabinet instead.  I like the functionality here, and probably works for a lot of people better then a true arcade look/feel since it could be used for more then one thing.  But if you will only use it for arcade games, you might want it to look like an arcade machine at the same time.
good luck and post picts
MYX
    • MYX Digital Blog
Re: My idea
« Reply #5 on: January 30, 2006, 08:19:20 am »
For as much as I hop around while playing, I would probably kill myself sitting down. This is probably why I do not like cocktails.
M    Y    X
Gradius
Re: My idea
« Reply #6 on: January 30, 2006, 08:53:43 am »
But a few things
I've considered ergonomics as the most important factor. I can tell you that my design is thousand times more comfortable than a standard japanese sit-dow cabinets. These force you to keep your back straight, with no place for your legs. The position I take for playing is like the one in the picture, and I can play for hours. The position of the neck is perfect. It's natural. What is not natural is to look up. An example. Sit on a chair in front of your computer in the position you normally take for typing and try this: what is more comfortable, too look for 3 hours to your keyboard or to look for 3 hours at a a the wall in front of your at the level of your head? When you feel tired you end up looking down.
My CP is heavy (it has a base made or iron). Moreover, it has ant slippery pieces that makes it impossible to move, unless you grab it an lift it. A CP with fixed position is always an inconvenience. An example: you never play centered because each player is on each side.
Code: [Select]
I have another computer for working and playing PC games, with a normal table and a mutisync monitor.  This is only for MAME and movies (ArcadeVGA + SCART TV). The keyboard is used rarely.
As I said the monitor has two normal positions (not talking about vertical or horizontal now): inclined and not inclined. The first one is for gaming. The second one is for movies.
I know it doesn't look authentic, but I prefer something ergonomic, practical, comfortable and modular (even only for gaming) rather than a beautiful cabinet. Also, if I decided to build a real cabinet I would have to build two: one with horizontal monitor and other with vertical monitor. With this design I have everything.
soulblazer28
  • Last login:September 27, 2009, 09:12:17 pm
Re: My idea
« Reply #7 on: January 30, 2006, 10:39:41 pm »
I sit at a computer 14 hours a day. I couldn't imagine having my computer monitor at that angle and distance.  I don't think I'd be comfortable playing games at all, especially considering im 6'1".
Personally, I need the body stability of being on my feet and having one foot slightly forward than the other. For marathon play, I used to sit on bar stools the local arcade used to have.
But if this works for you, I applaud your design. Right now I'm at the point of deciding what to build and it's nice to see different ideas. :laugh:
