Author Topic: Trade/Want List (console, arcade, PC, other) [US]  (Read 6471 times)
o-o
  • Last login:January 13, 2023, 05:40:36 am
« on: January 28, 2006, 07:57:56 am »
Available Console:
-Saturn (Sega 1st party) complete controller PCB with cable
-Saturn (Sega 1st party) controller encoder chip and cable
-Genesis (Sega 1st party) controller encoder chip and cable
-NES (Nintendo 1st party) controller cable, encoder chip
-Pelican Real Arcade Stick Universal (nice wood version) (Mint/Excellent/like-new condition, in box Complete with everything, adapts to: PS2/PSX, GameCube, Xbox (with memory port))
[SOLD] ##-Sega CD system package (Sega CD version 2 + Genesis version 1 + base extension, complete with hookups, power supplies, mix cable, and *sterio A/V cable*)##
-Sega Genesis console (version 1 with hookups/controller)
-Playstation 1 system (model 7501) [just hub part is broken, everything else is good, no hookups]
-Turbografx16 AC adapter
-Turbografx16 RF adapter
-Sega 32X genesis adapter cable
-Genesis Competition Pro pad   (*all contacts large and easy to solder*, has rapidfire switch for each button, and slowmotion)
-Intellivision overlays/slipcards: Burgertime [x2], Atlantis [x1]
-[tabletop vintage handheld] Bambino 2player Knock-Em Out Boxing (large 1-2player handheld/tabletop, tan/brown version)
Available PC:
-Antec 250W ATX PSU (PP-253X) [Switching, Smart Fan]
-[*NEW in box*] Startech FAN370CU Socket-A/Socket-370 *Copper Base* HSF(heatsink/fan combo)
-Athlon Slot-A 500mhz+ (700mhz) CPU (with overclock dipswitches mod up to: 1/2 cache, 700mhz, etc.. adjustments chart included) with enormous *ALPHA* dual-fan HSF excellent cooler
-Athlon Slot-A 550mhz CPU in case with HSF (might have some burn in if thats even possible with this, asis/untested)
-[NEW/unused, with box] large dualfan Slot-A heatsink with clip arms (no fans)
-Verbatim Data Life Plus CDRW's (Unopened, sealed with full jewelcases including labeling inserts)
-NTI CD Maker Pro (in original sleeve) + unopened Verbatim Data Life Plus _Direct Write_ CDRW (sealed in full jewelcase with labeling insert)
-Asus K7M motherboard (just one IC next to the PCI slots blew) (cpu arms and bios chip included)
-Logitech Wingman Extreme flightstick (complete with box and manual [*details all pinout info*]) (it just wasnt transmitting left movement last tested)
-Wacom Digitizer SD-510C graphic tablet 6x9" (complete with tablet, cordless pen, pen holder, base unit, and power cable) (just needs a cable from Wacom, or a modified regular serial cable)
Available Electronics:
-Casio FX-115n Scientific Calculator (complete with manual, box and everything..)
[SOLD] ##-Texas Instruments TI-81 Graphing Calculator##
-Radio Shack digital answering machine (add to any phone) [unused]
-Centerex power strips (7 outlets each, surge suppression, on/off switch + power light)
-variable resistors (PCB-mount):  100ohm [x98] , 1k ohm [x50] , 1Meg ohm [x50]
-potentiometers: (CENTRALAB Model-2) 1A 250V - 3A 125V   [x10]
-fuses:  GMA 2 Amp Fast Blow (250 volt 5mm x 20mm)  [x4]
-variable power supply: (PP-6917/GR) variable 0 TO 28 VDC @ 800mA (enclosed unit with grounded power cable)
-knobs: large deluxe high quality (MXR style) screw-tighten knobs (1.25" Width x .75" Height)
-Keychain RAM/SIMMs [good for keychains]
Available Other:
-music equipment (rackmount amps, rackmount and pedal effects filters, etc..)
-cards
-coins
-comics
-music CD's
-movies (VHS)
Wanted Arcade:
-arcade stick enclosures (RedOctane or other/homemade) (black) [x2+]
-joysticks: Competition joystick, Happs Super, Mag Stik, Ultimarc T-stick, or other ball-top short travel, Sanwa / Seimitsu (all black)
-buttons: happs concave (one of each color etc..), and convex (8 black), start buttons [x2-4], Sanwa / Seimitsu (black 8+)
-buttons from Pelican Real Arcade Sticks (anyone have these leftover from a mod?)
-button wrench
Wanted Modwork:
-Controller adapter module: "to>PS2" (with selecable rapidfire button)
-Controller adapter module: "to>Saturn" (with selecable rapidfire button) [*I have the controller/PCB for it*]
-Controller adapter module: "to>Dreamcast" (with port for mem card) [*I have the controller/PCB for it*]
-Controller mods (controllers modded with 'generic'/straight button-out cables attached, rather than their encoder/system-specific cables): Saturn, SNES (dont have), Xbox, N64, SMS (dont have)
-Arcade stick housings built
Wanted Console:
-Pelican A/V selector switcher [x3-4]
-adapters: Xbox Magic Box, Dreambox, XP Joybox, DC Skillz DreamConnection, USB to Xbox
-PS2 or PS1 rapidfire controller (damaged ok, or just the PCB/cable)
-Saturn MadCatz rapidfire controller (damaged ok, or just the PCB/cable)
-standard controllers: SNES, SMS, PS2 and PS1 (also non-dualshock), Xbox, Saturn (or just the rubber contacts), Genesis (need just 1+ rubber button contact..)
-controller extension cables and S-video cables (Saturn, Dreamcast, PS1/PS2, Xbox, GameCube)
-PS2/Xbox: Pelican Tomahawk flightstick [x1-2], Interact V3 wheel, Gamester/Radica FPS Master, Pheonix Revoltion, GRIPs
-PS1: memory cards, power cable, chip, motor/laser assembly (compatible with model 7501 and 5501), plugmod
-games: Xbox, PS1, PS2, DC, Saturn, GC
-Sega Saturn console (just the base unit w/o hookups)
-Sega Saturn console (modded auto/switchless)
-Gamecube (black)
-Xbox
-DVD cases (black)
Wanted PC:
-Windows 2000
-PC games, strategy guides
-CH Flightstick Pro gameport version (broken ok) [x2]
-hard drives (6Gb+)
-external 3.5 drive USB enclosures
-internal drive mount extenders
-agp video card (4mb-32mb+ nvidia based)
-floppy drive (black) [x2-3]
-USR Courier v.Everything modem (external)
-PC case: Powmax 9804SEL (black) [x2]
-rack PC case (for standard size hardware)
-rack keyboard drawer
-parts for lowering fan speeds (or baybus fanbus parts/system)
-lefthand keyboard (or Ergoflex or Ergomagic), black keyboard, black mouse (optical, not wireless) [x2]
-happauge tv tuner card (with composite and svideo In, directdraw capable)
-keyboard and mouse extension cables (ps/2) [x4]
-network cable (around 18ft+)
-Svideo to composite(RCA) adapter, and Svideo cable (15-25ft)
-DVI cables (8ft+) [x2]
-round dual IDE cables, round floppydrive cables
-fans: 120mm, 80mm quiet
-old 5volt Smartmedia (2-4mb), and 5volt Smartmedia reader (for the old 5volt type of Smartmedia)
-Compact Flash card (32mb+)
-electronics parts:  jacks (1/8" and 1/4"), rocker switches (round hole mount, black or lighted)
  soldering station (Weller or Tenma), multimeter (Fluke)
« Last Edit: April 14, 2006, 08:21:14 pm by o-o »
TravistyOJ
  • Last login:September 19, 2020, 09:34:19 pm
  • DRK LFG!
Re: Trade/Want List (console, arcade, PC, misc.) [US]
« Reply #1 on: January 28, 2006, 11:19:59 am »
I really dont have much to offer that you want, maybe some PS1 motor/laser assemblies.  How much cash would i have to add to that for the Sega CD?  Thanks
"It is a mistake to think you can solve any major problems just with potatoes."
-Douglas Adams
lcddream
  • Last login:January 06, 2020, 06:56:49 pm
  • Say goodbye to gravity...
« Reply #2 on: January 28, 2006, 02:52:00 pm »
what guitar pedals do you have?
nullb0y
  • Last login:March 27, 2023, 04:37:32 pm
  • Who wants some?
    • antinull
« Reply #3 on: January 28, 2006, 06:00:31 pm »
i want the art tablet
also the heatsink intrests me
i have a ps2 con with auto fire i think i have 2 actually
also i have a stack of xbox games
mechassult and linux installer mem card
ssx tricky
thug
enter the matrix
thps4
crazy taxi 3 high rollers
halo
and the sega gt and jetset radio future dual disc
i also have a nvuidia 5200 (128 meg)  untested
oh an i can get laser assemblies for ps1
« Last Edit: January 28, 2006, 06:22:59 pm by nullb0y »
Alright. Who wants some? Who's next? Huh? How 'bout it? Who wants some? Huh? Who wants to have a little? You.
  You want some more? Huuuh? You want a little? Do ya? Huh? You want some more? Huh? Huh? Hh!
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
« Reply #4 on: January 29, 2006, 07:45:25 am »
I have the following to offer to trade if interested:
- Ultimate mortkal kombat 3 pcb- works well
- ms pacman original cocktail table power supply and wiring harness- lots of wires, not tested
- 15" black computer monitor-  works well
- tektronics 8200 color printer- works well
- Double Dragon 2 pcb- has yellow hue on screen, otherwise works well
- clear green dvd case holder
« Last Edit: February 25, 2006, 07:19:32 am by kjoel0123 »
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
o-o
« Reply #5 on: January 30, 2006, 09:34:28 am »
TravistyOJ,
I'll pm you
lcddream,
of effects I have:
DOD Sterio Bass Flanger pedal
DOD Octoplus pedal (footswitch is a little finiky but easily replaceable)
PAiA Vocoder rackmount
nullb0y,
Which heatsink(s) are you intersted in?
What brand/model are those PS2 controllers, and the Nvidia 5200 card?
What condition/completeness are the Xbox games (any more)? (is the mem card 1st party?)
kjoel0123,
I dont need any of those (unless the 15" monitor happens to be lcd)
(lists updated)
o-o
« Reply #6 on: February 07, 2006, 07:11:12 pm »
^ (list updated)
o-o
Re: Trade/Want List (console, arcade, PC, other) [US]
« Reply #7 on: March 05, 2006, 11:12:36 am »
testicle187
  • Last login:September 21, 2022, 09:34:53 am
« Reply #8 on: March 10, 2006, 02:37:45 am »
PM sent...
o-o
« Reply #9 on: March 26, 2006, 08:50:24 am »
PM replied
SpeedEng
  • Last login:May 26, 2015, 01:31:42 am
  • one day I will finish
« Reply #10 on: March 26, 2006, 10:15:25 am »
I have the following items
 model i cant recall at the sec (let you know when I get home)
a few mem cards
o-o
« Reply #11 on: March 27, 2006, 09:05:16 am »
Are any of the PS1 mem cards sony (grey or clear) or?
Does the controller work like this with just one rapidfire assign button:
press the "rapid-fire assign" button once, then press any buttons you want to have rapidfire, then press the "rapid-fire assign" button again to confirm it.
Then all those buttons you chose have rapid fire, while rest of the buttons _remain normal_.
(so you can have some be rapidfire and some not)
Are you saying you only have the controller and psx mem cards, or some of the other items you pasted?
thanks
SpeedEng
« Reply #12 on: March 27, 2006, 04:23:50 pm »
the memory cards are sony
2 greys, one black, (might have more)
as for the controller there is a switch on it to turn auto on. a switch for each button
oh my bad I just cut and pasted off your post
all I have is the items posted above.. :(
MajorLag
  • I'd say the same about a good chunk of the people posting in PnR, including myself.
  • Last login:July 11, 2013, 03:54:10 pm
  • Damn you party liquor!
« Reply #13 on: March 27, 2006, 04:42:26 pm »
-variable power supply: (PP-6917/GR) variable 0 TO 28 VDC @ 800MA
Surely you mean 800mA?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #14 on: April 09, 2006, 08:44:04 pm »
Heres a pic of what I want to send
all the buttons from a Pelican Real Arcade Stick Xbox
all the buttons and the joy from a Pelican Real Arcade Stick Universal.
All in brand new great condition.
« Last Edit: April 09, 2006, 09:02:06 pm by timoe »
Paik4Life
  • Last login:December 01, 2020, 12:03:48 am
« Reply #15 on: April 09, 2006, 09:12:23 pm »
Just to let you know Sanwa doesn't make black buttons only black balltops (don't ask me why...it makes no sense to me).  So if you want Japanese style black buttons then you'll have to go Seimitsu.  The only place I know who sells Seimitsu parts is Akihabara Shop or if you have a Japanese address or friend then you can order directly from Seimitsu.
Also, I do make custom sticks (Sanwa/Seimitsu parts, 6 button Japanes layout, PS1 DualShock).  I'm not sure if you're looking for used or new though.  If you're looking for used, I can't help you.  The way I build sticks is different than 95% of the people out there since I build the stick out of a solid block of material (either MDF boards that are joined into a solid block or an actual solid block of wood).  I route out the necessary areas and shape the case.  I also use metal plates to mount the buttons and a metal plate for a bottom cover.  So I could kind of kill two birds with one stone by making you a stick with Seimitsu parts.  Here's a link to my album so you can see:
http://s10.photobucket.com/albums/a141/Paik4Life/
The finkle album is a stick build from a case a friend of mine built and I modded it with parts and stuff so that's not very relevant.  The other albums show my sticks that I've made/sold with work in progress photos so my customers can see the progress.  It'll also give you an idea of how it's constructed.  The only stick I currently have is the "Green" stick in the "Useful Photos" ablum.  I just made that last week just for kicks.  It's pretty boring though compared to my normal design.  Anyway, this info might be pointless so I'll stop there.  If you're interested just PM me.  Hopefully, some part of this was remotely helpful for you.  Take care.
~Paik
P.S.  I'm making a parts order at the end of the week since I need parts for some stick orders.  If you're interested in a stick, I would suggest getting in on this order since I am splitting the S&H costs between everyone in the order evenly and it might be a while before I order again.
« Last Edit: April 09, 2006, 09:15:45 pm by Paik4Life »
o-o
« Reply #16 on: April 14, 2006, 08:46:15 pm »
Paik4Life,
Im only able to trade at the moment, I might be looking to buy sometime in the future though but Id be wanting a different design than those (interesting though, are the tops/faces to the Finkle sticks metal also?)
thanks
« Last Edit: April 14, 2006, 09:17:07 pm by o-o »
SithMaster
« Reply #17 on: April 14, 2006, 10:19:39 pm »
what cards do you have?
Paik4Life
« Reply #18 on: April 15, 2006, 01:49:36 am »
o-o, that's cool.  The finkle isn't my own stick.  It's a case that I modded.  The case was made by a guy that goes by finkle on the SRK boards.  Very nice guy and a pleasure to work with.  His cases are all metal and very sturdy.  The others are mine.  They are made of either MDF or cherry blocks.  The only exception is the stainable case I'm working on which is a hybrid of MDF and cherry.  Anyway, best of luck with trading and such!
~Paik
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #19 on: April 15, 2006, 04:49:55 am »
Those things look awesome. Very nice craftsmanship. Please post pics when the cherry one when is complete!
-pmc
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #20 on: April 17, 2006, 02:59:10 pm »
Thanks for the pots and knobs, o-o,  they look great.
o-o
« Reply #21 on: April 24, 2006, 01:39:52 pm »
SpeedEng,
PM'ed you
