Main > Main Forum
Are all LEDs the same quality?
Pages: << < (6/6)
rackoon:
Well I ended up buying 100 UV leds through eBay. 1$ plus $11 shipping from Hong Kong.
I believe that they are 3mm,  2000mcd, 15degree view angle. I'm going to use almost all of them. I will experiment with the sandpaper and grinding the bulb flat.
     I have 24 buttons and a recessed diamond plate kick plate at the bottom that I want to bounce UV light off. I am working on a three sided cocktail and might shine some down under each CP also. Heck, I would mount a freak'en disco ball to it if my wife would let me..well maybe not but I am trying to recreate the arcade feel that I used to experience back in the 80's. UV black lights were quite popular.
    Any way I will post pics when I get far enough.
juggle50:
Cool idea racoon.
I do have a soldering iron.  I just suck at it and was just seeing if there was a way around it.  However, I'm running about 10 of the same lights in parrallel and the way I understand it I only need one resistor right?
cholin:
Yes.
rugby1:
--- Quote from: mahuti on January 31, 2006, 02:21:12 pm ---Rugby1, DUDE, you are either ON the bus or OFF the bus... which WAY is it GONNA be.
Well,  I'm definately off that bus.... gonna go get on the little yellow special kids bus first     ;D
RandyT:
--- Quote from: rugby1 on February 01, 2006, 03:57:13 pm ---
I'd rather lie under the wheels......
RandyT
Pages: << < (6/6)
Go to full version
