Author Topic: Which joysticks let you change from 4-way to 8-way from the top?  (Read 1553 times)
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
Howdy,
Which joysticks will let me change from 4-way to 8-way movement without having to get at the inside of the CP?  I know the Ultimarc Mag-Stik Plus can do this but are there any other joysticks that can do this as well?
Thanks.
« Last Edit: January 27, 2006, 02:55:47 pm by kelemvor »
BULL
  • Last login:March 03, 2011, 02:18:08 am
  • GAUNTLET FOREVER
rwhip41
  • Last login:April 04, 2006, 12:46:36 am
Re: Which joysticks let you change frmo 4-way to 8-way from the top?
« Reply #2 on: January 27, 2006, 02:44:09 pm »
Yes. Ultimarc sells them. They used to be called the T-Stik Plus. Now they are called the Mag-Stik Plus.
I have a T-Stik Plus and I really like the 4/8 way interchangability...just lift and twist the stick from the top. The only knock is that the stick has a somewhat short throw, meaning that it doesn't have much travel moving from the center to whatever position you want. Some people like that. I got used to it and now I like that.
Here's a link to the Ultimarc web site where the controllers are listed...
http://www.ultimarc.com/controls.html
Necro
  • Last login:November 29, 2022, 08:22:22 pm
Re: Which joysticks let you change from 4-way to 8-way from the top?
« Reply #3 on: January 27, 2006, 03:05:41 pm »
Do the OmniSticks HAVE to be top mounted or can you mount them from below somehow?
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #4 on: January 27, 2006, 03:06:44 pm »
They used to be a DIFFERENT stick called the T-Stick Plus. However, the return mech on the Mag-Stik plus is different, but the functionality (switching) is the same.
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #5 on: January 27, 2006, 03:06:47 pm »
The only ones that allow you to do it from the top of the panel are:
- T-stick Plus
- Mag Stick Plus
- OmniStck Prodigy (all the versions linked up above)
The T-Stick has been replaced by the Mag Stick, but you can still find them if you really needed a T Stick instead of a Mag Stick.
first off your and idiot
mahuti
« Reply #6 on: January 27, 2006, 03:14:29 pm »
Yeah, I have a pile of various T-sticks. One of these days I'll have to sell em.
(nothing wrong with them, I just keep upgrading when something newer comes out.)
Also... if you feel like burning a weekend...
You can get the GPwiz49 and a 49way stick some software...and have your stick auto-convert to your hearts content.
420
  • Last login:August 01, 2012, 09:54:23 pm
« Reply #7 on: January 27, 2006, 11:23:24 pm »
I have a X-Arcade with the OmniStick mounted from below. It took a little work, I had to remove the mounting plate, and move the lever to the ajacent side (so it would fit the routed area and still have the lever on top). I suppose drilling the holes can be tricky for some.
here are some shots....
