Author Topic: epsxe in mamewah - doesn't generate a list  (Read 1411 times)
panterafreak
  • Last login:June 09, 2010, 08:28:28 pm
« on: January 23, 2006, 10:04:11 am »
Ok so I have mamewah 1.61 and epsxe 1.60 and am trying to get epsxe inside of the mamewah interface.  I searched google for an example and followed that best I could but while the epsxe works outside of mamewah it only shows as an entry with no games (I have 5 or so it should pick up).  I tell it to "generate list" but no love.
Here is my epsxe.ini
Code: [Select]
### epsxe.ini (mamewah v1.61) ###
emulator_title                            Playstation
### List Generation Settings ###
rom_path
rom_extension                             bat
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
emulator_executable
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Taking a suggestion from the example I found I have a batch file (.bat) to fire off each game, here is an example:
Code: [Select]
c:
cd\mamewah\emulators\epsxe\
ePSXe.exe -nogui -loadbin c:\mamewah\roms\epsxe\gg.bin
LJHalfbreed
  • Last login:April 13, 2006, 09:10:21 am
  • I'm a mammal!
Re: epsxe in mamewah - doesn't generate a list
« Reply #1 on: January 23, 2006, 10:13:20 am »
rom_path
rom_extension                             bat
dat_file
nms_file
catver_ini_file
Change the list method to just rom_folder...  and your rom_path to your rom path...
Check Jcrouse's site for some pretty helpful ini's to start you off...
http://home.comcast.net/~cpviewer/
panterafreak
« Reply #2 on: January 23, 2006, 01:42:54 pm »
Ok that got it to generate a list (thanks!), however now when I select a game from the list it doesn't launch.  Usually you highlight the game and then hit enter to launch, it just sits there doin nothing.  Any ideas?
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« Reply #3 on: January 23, 2006, 06:46:07 pm »
Try hitting "1" to launch. That's the default behavior.
panterafreak
« Reply #4 on: January 23, 2006, 09:09:54 pm »
Nope, doesnt work with 1 or enter whereas that works with the other emulators I have installed (mamewah draxsynn pack).
« Reply #5 on: January 24, 2006, 06:32:21 am »
As LJHalfbreed said, check out JCrouse's site (it has an example for epsxe).
Basically your commandline_format is incorrect...for starters {autodosbox} only works with MAME.
panterafreak
« Reply #6 on: January 24, 2006, 09:45:47 am »
Thanks guys, that second push towards the site with examples helped, missed the playstation one below, everything is working now after I renamed the layouts files and renamed my cd images to .bin.
Much appreciated!
