| Main > Lightguns |
| WOW New LightGUN Info !!! Woot!!! :) |
| << < (136/378) > >> |
| Farmboy90:
I don't think resolution changes affect the gun at all. I bounce around from game to game with no issues. |
| Fozzy The Bear:
--- Quote from: ChodTheWacko on February 03, 2006, 11:10:07 pm ---If you have to calibrate the gun at the resolution you play the game at (for example, my laptop is 1024x768, and I forced mame to play at that res which worked fine). How do you get a game like mad dog mccree to work? Do you actually desrez your screen down to 320x200, and then calibrate your gun? --- End quote --- Hello Frank, Resolution changes don't affect the hardware calibration of the gun, because it's not based on the screen pixels, it's based on the gun seeing the position of the LEDs on the two stands. Software calibration however, may sometimes need to be done again. I haven't hit any problems with it though. The answer here is give it a try and see what happens. If you find it's out of calibration, then just run the software calibration again. Best Regards, Julian (Fozzy The Bear) |
| brandon:
I know this is sort of beside the point right now but.. what if you could somehow take the raw data from the gun and convert it to X-Y axis joystick coordinates? Then you could have as many guns as you like and they would not conflict.. and screen resolution shouldn't matter in that case.. maybe somebody has already tried this.. just a thought.. |
| ChodTheWacko:
--- Quote from: Fozzy The Bear on February 04, 2006, 01:20:45 am ---The answer here is give it a try and see what happens. If you find it's out of calibration, then just run the software calibration again. --- End quote --- No dice, I tried house of the dead, and mad dog mcreee, and the virtua squad demo, and all three were unplayable. The cursor was just all over the place. Maybe Ishould change drivers. I also tried lethal enforcers with the modified mame, and the shooting part works great, I could shoot people accurately. However the offscreen reloading doesn't work, it counts as a missed shot. I did some searches and I guess I'm missing something. I tried the -reload option, which didn't do anything. I also noticed that the right mouse button, which reloads on some games,doesn't reload for LE either, so maybe that's the root problem. |
| aljupy:
Hi: I received mine yesterday. Tracking is very bad in comparasion with SILVER |
| Navigation |
| Message Index |
| Next page |
| Previous page |
