Main > Lightguns
WOW New LightGUN Info !!! Woot!!! :)
<< < (371/378) > >>
aljupy:
Ok, now I understand your fears, I didn´t know why you didn´want to install the new EMS driver.
NOTHING TO FEAR RIGHT NOW, I had the SMOG´S driver for a lot of years, and it gives not any problem to Switch to the EMS one.
You DO NOT need to erase/Uninstall Windows nor even format the Hard Disk.
I have used the WINDOWS SP3 for this ;)
After installing it I can turn ON  PC and it will not ask nothing about drivers. And I can connec my TOPGUN Before turning ON PC
Higly recommended
Regards
aljupy:
Of course I UNINSTALLED Smog´s Driver.
Just Uninstall Smog´s one, Reset your PC, and install EMS  one
arbrandes:
--- Quote from: ChicagoDave on May 11, 2008, 01:15:37 pm ---Thanks, can you  boot the system with both guns plugged in?  With Smog's driver, my system would lock up when the guns were plugged in a boot time.
I use Linux and have the same problem: if the gun is plugged in, the computer won't boot.  I don't think this has anything to do with drivers.  It is a hardware issue.  Just one more of the TopGun's quirks, I guess.
aljupy:
I can turn ON my PC with TOP GUNS connected before it turns ON.
But as it says above, that is not a driver issue.
My Topguns are bought on the same month of released.
I would like to know your thoughts, this new EMS driver is pretty good.  :applaud: :applaud:
TPB:
--- Quote from: aljupy on May 10, 2008, 05:06:59 am ---http://www.hkems.com/download%20-%20TopGun.htm
The driver's still a Beta version.
Is it stable ?
Does it have debugging code embedded into it ?
Are EMS conducting a Beta testing program, to iron out any bugs ?
Any word from EMS, as to when the final Production version of the driver shall be released ?
I guess no-one has the answers ... except perhaps the EMS reps. in Hong Kong, but I doubt they're regular visitors to the BYOAC forums.    ???
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
