Author Topic: Games for a Spinner?  (Read 1046 times)
lovespicyfood
  • Last login:December 03, 2019, 12:37:08 am
« on: January 22, 2006, 05:07:14 pm »
Okay, I have very fond memories of Tempest, but besides that game, I can't remember many that used the spinner.  I used to love Frontline, but if I remember right, that was a positional spinner which may not work w/ the type of spinner I'm thinking of...
I'm in the planning stages of my arcade build-out and *think* I want a cp w/ 2 joysticks (probably 4-8 switchable Magstick Plus'), a 3" trackball (probably a Happs) and a spinner.
The more I think about it, perhaps I don't need a spinner?  Would I be better off putting a dedicated 4 way stick in its place?
I barely remember Tron.  Does Tron necessiate that I buy a push-pull spinner or can that be accomplished w/ a normal spinner and a joystick?
Any thoughts or advice is much appreciated!  I figure the more research I can do now in the planning stages, the better off I will be in the long run!
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
Re: Games for a Spinner?
« Reply #1 on: January 22, 2006, 05:31:55 pm »
Warlords
Discs of Tron
Arknoid (or any similar... breakout etc.)
These are games that just aren't the same without a spinner
You could potentially use it for
Super Sprint
Off road
Just some of my favourites off of the top of my head.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
vizzinni
  • Last login:October 06, 2022, 06:04:10 am
  • Inconceivable
« Reply #2 on: January 22, 2006, 05:42:41 pm »
You could also use a spinner for Omega Race and Arkanoid, as well as Tempest.  Also for many driving games like Pole Position and Iron Man Stewart's Off Road, in lieu of a steering wheel; it's not the same, but it's better than a mouse or joystick.
I think it was Discs of Tron that used the push-pull spinner. Tron uses a spinner along with a trigger joystick.  It's really tough to play even with a spinner using a regular joystick like a Happ Super.
Personally, I put a lot of effort into building my own spinner, and I even bought an Oscar MAME knob for it.  Had a great time doing it and it works great, but I really don't use it much!   If you like driving games and don't envision building/buying wheel controls, maybe you'd use the spinner.  Otherwise, if you're not a Tempest addict, maybe you could do without.  Probably ought to come down to budget issues rather than space, since it shouldn't take much space on a two player CP.
That's just my 2 cents.  I'm sure you'll hear more examples of spinner games from others...
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #3 on: January 22, 2006, 06:12:04 pm »
You could always try it with a mouse in MAME.
Unless you want a specific 4 way, the 4/8 way switchable IS an official hardware restricted 4 way, so I don't see the value in that.
until you get to the higher levels you could accomplish what you need to with a topfire stick and a normal spinner. Once you get past the first few levels though.. it really needs the up/down spinner.
Click here for a pretty good list of spinner games
OH, and "search is your friend", as is the stickied FAQ at the top. These topics have been all been covered pretty extensively.
1. 4/8 way switchable vs. dedicated controls (might also see GP-wiz & 49 way joystick topics)
2. discs of tron options
3. spinner games & favorites.
4. control panel planning & building.
Note; Not trying to give you a hard time... there has just been some pretty extensive discussion about all of these things in the past that will provide a wealth of information.
GGKoul
  • Cheesecake Apprentice
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #5 on: January 22, 2006, 10:26:55 pm »
hey, only DISCS OF TRON uses a push-pull spinner. Original TRON uses a regular spinner.
NO MORE!!
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #6 on: January 22, 2006, 11:07:03 pm »
And Zwackery!
Kremmit
  • - AHOTW -
« Reply #7 on: January 22, 2006, 11:14:54 pm »
Correct.
The Frontline "spinner" is really a topfire joystick underneath the panel.  It uses a rotary knob to determine which position the joystick is pointing, and you push down on the knob to activate the button.  There's no reason you couldn't play Frontline with a topfire stick in place of the "spinner".
